Einleitung
The charging port is where the charger plugs into the phone. If this piece is damaged, the phone might not be able to charge. Make sure you have tried cleaning the port before jumping into this replacement.
Was du brauchst
Insert the end of a paper clip into the holes on each side of the phone to eject the SIM card and Micro SD card.
Set the cardholders aside.
Use a metal spudger to pry up the left edge of the upper grey front plate.
Use the narrow plastic pry tool to carefully separate the black ribbon antenna from the grey plate.
Use the plastic pry tool to pry around the edge of the phone.
Slowly pull up from the right side of the screen like opening a book.
Use the plastic spudger to peel the foam adhesive around the camera away from the back plate.
Peel off the long yellow pieces of tape on the right and left side of the copper plate.
Starting from the copper plate, peel up all three woven, silver colored tapes using the spudger or narrow pry tool.
Using the flat end of the spudger, pop up the white tabs on all ribbon cable connectors located to the left and right of the copper plate.
Carefully pull out the ribbon cables.
Using a Phillips #00 screwdriver, unscrew the two 1 mm screws from the bottom right corner of the motherboard that hold the power connector down.
Pop up the battery connector using the flat end of the spudger.
Use the pointed end of the spudger to pop off the four antenna connectors. Three are located on the top left corner of the motherboard and one on the bottom right.
Using the pointed end of the spudger, pull the wires for the rumble motor to the left to pull the connector out of the board.
Using a T5 torx screwdriver, remove four 2mm screws from the four corners of the motherboard.
Once the screws are removed, carefully pull the copper plated motherboard out.
Use the narrow plastic tool to pry up the black foam covered rectangular connector.
Use the flat end of the plastic spudger to pry the lower speaker out.
Holding the phone, pull the speaker to the right pulling the connector out of the board.
Use the T5 torx screwdriver from the iFixit toolkit to remove the two 2mm screws that hold the power connector board in.
Pull the board out.
8 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
I wanna take to a shop and pay for the repairs.Please could you give me places to go
Please advise me on any places I could take my phone for repair.I live in the Sydney area.
