Einleitung
This guide will walk you through the process of replacing a motherboard in an HTC One Remix.
  1. Use the sim eject tool to remove the SIM cards on either side of the phone.
    • Use the sim eject tool to remove the SIM cards on either side of the phone.
  2. Heat up the iOpener in the microwave for one minute. Place the iOpener on the top of the phone for three minutes.
    • Heat up the iOpener in the microwave for one minute. Place the iOpener on the top of the phone for three minutes.
    • iOpener Anleitung
  3. Once the top of the phone is warm, use a plastic spudger to pry the top left corner up.
    • Once the top of the phone is warm, use a plastic spudger to pry the top left corner up.
    • The top is glued on so it may be difficult to get off.
  4. Take out the small 3 mm screw that is on the top left side using a T5 bit.
    • Take out the small 3 mm screw that is on the top left side using a T5 bit.
  5. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  6. Use the plastic spudger to pry off the back cover. Place the tool in the SIM card insert and lift off the back cover with force. Continue to do this all around the phone. Be careful to not break the wiring that is connected from the inside to the back of the phone.
    • Use the plastic spudger to pry off the back cover. Place the tool in the SIM card insert and lift off the back cover with force. Continue to do this all around the phone.
    • Be careful to not break the wiring that is connected from the inside to the back of the phone.
    • The plastic spudger may not work. If this is the case, you may have to resort to using the metal prying tool. Please use with caution.
  7. With tweezers, remove the small pieces of yellow tape that hold the phone in place. Use the plastic prying tool to take off the three pieces of silver tape. They are located at the bottom right corner of the copper place.
    • With tweezers, remove the small pieces of yellow tape that hold the phone in place.
    • Use the plastic prying tool to take off the three pieces of silver tape. They are located at the bottom right corner of the copper place.
    • Please note that the second photo is upside-down.
  8. With the plastic spudger, disconnect the eight ZIF connectors. Do this by lifting the small white lines up and pulling the ribbon from it. Use tweezers to carefully detach the eight ribbon cables from the connectors. Use tweezers to carefully detach the eight ribbon cables from the connectors.
    • With the plastic spudger, disconnect the eight ZIF connectors. Do this by lifting the small white lines up and pulling the ribbon from it.
    • Use tweezers to carefully detach the eight ribbon cables from the connectors.
  9. Remove the two 1 mm screws at the bottom right of the motherboard using a Phillips #00 screwdriver.
    • Remove the two 1 mm screws at the bottom right of the motherboard using a Phillips #00 screwdriver.
  10. Pull off one end of each of the five colored connecting cables from the motherboard. Pull the black and red wire from the motherboard on the bottom left.
    • Pull off one end of each of the five colored connecting cables from the motherboard.
    • Pull the black and red wire from the motherboard on the bottom left.
  11. Take out the four 3 mm screws that are on each corner of the motherboard using a Torx 4 screwdriver.
    • Take out the four 3 mm screws that are on each corner of the motherboard using a Torx 4 screwdriver.
    • Gently lift the motherboard out of the phone using the plastic spudger.
    • Watch the ribbon connectors when removing the motherboard as they may get in the way.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Marcos Loza
936 Reputation
4 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 66
