Zum Hauptinhalt wechseln
HTC One V Vibrator Replacement
Was du brauchst
  1. HTC One V Vibrator Replacement, Disassembling HTC ONE V Bottom Assembly: Schritt 1, Bild 1 von 3 HTC One V Vibrator Replacement, Disassembling HTC ONE V Bottom Assembly: Schritt 1, Bild 2 von 3 HTC One V Vibrator Replacement, Disassembling HTC ONE V Bottom Assembly: Schritt 1, Bild 3 von 3
    • Power off your device.
    • Remove the bottom cover by sliding it off.
  2. HTC One V Vibrator Replacement: Schritt 2, Bild 1 von 1
    • Remove the SIM card.
    • Remove the four screws securing the bottom casing.
    • Two 3.0 mm Phillips #0 screws in the top left and right corners.
    • Two 2.0 mm Phillips #0 screws in the bottom left and right corners.
  3. HTC One V Vibrator Replacement: Schritt 3, Bild 1 von 2 HTC One V Vibrator Replacement: Schritt 3, Bild 2 von 2
    • Remove the 2.0 mm Phillips #0 screws on either side of the phone.
  4. HTC One V Vibrator Replacement: Schritt 4, Bild 1 von 3 HTC One V Vibrator Replacement: Schritt 4, Bild 2 von 3 HTC One V Vibrator Replacement: Schritt 4, Bild 3 von 3
    • Use a plastic opening tool to pry open the bottom casing.
    • Remove the bottom casing by pulling it towards you.
  5. HTC One V Vibrator Replacement, Disassembling HTC One V Back Case: Schritt 5, Bild 1 von 3 HTC One V Vibrator Replacement, Disassembling HTC One V Back Case: Schritt 5, Bild 2 von 3 HTC One V Vibrator Replacement, Disassembling HTC One V Back Case: Schritt 5, Bild 3 von 3
    • Use the plastic opening tool to pry open the rear camera panel.
    • Remove both screws that are securing the back case.
    • One 4.0 mm Phillips #0 screw.
    • One 3.0 mm Phillips #0 screw.
  6. HTC One V Vibrator Replacement: Schritt 6, Bild 1 von 3 HTC One V Vibrator Replacement: Schritt 6, Bild 2 von 3 HTC One V Vibrator Replacement: Schritt 6, Bild 3 von 3
    • Use a Jimmy to pry up the OEM SIM and SD card reader contact.
    • Pry from right to left to avoid potential damages to the ribbon.
  7. HTC One V Vibrator Replacement: Schritt 7, Bild 1 von 3 HTC One V Vibrator Replacement: Schritt 7, Bild 2 von 3 HTC One V Vibrator Replacement: Schritt 7, Bild 3 von 3
    • Using both thumbs, gently push on the two bottom rear corners of the motherboard.
    • Gently and slowly pull the screen out from the front of the phone, while feeding the OEM reader contact through the opening.
  8. HTC One V Vibrator Replacement, Battery: Schritt 8, Bild 1 von 1
    • Pry up the battery with the flat end of the spudger.
  9. HTC One V Vibrator Replacement: Schritt 9, Bild 1 von 3 HTC One V Vibrator Replacement: Schritt 9, Bild 2 von 3 HTC One V Vibrator Replacement: Schritt 9, Bild 3 von 3
    • Gently lift up the battery away from the edge of its housing.
    • Use the point end of the spudger to push the connection out of its housing.
  10. HTC One V Vibrator Replacement, Camera Lens: Schritt 10, Bild 1 von 3 HTC One V Vibrator Replacement, Camera Lens: Schritt 10, Bild 2 von 3 HTC One V Vibrator Replacement, Camera Lens: Schritt 10, Bild 3 von 3
    • Remove the two 3.0 mm Phillips #0 screws, that are securing the camera lens.
  11. HTC One V Vibrator Replacement: Schritt 11, Bild 1 von 1
    • Pry off the camera lens using a plastic opening tool.
  12. HTC One V Vibrator Replacement, Vibrator: Schritt 12, Bild 1 von 2 HTC One V Vibrator Replacement, Vibrator: Schritt 12, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Pry the vibrator out of the housing with a spudger.
    • Using the tweezers, pull up on the connecting wires detaching the vibrator from the motherboard.
Abschluss
USF Tampa, Team 1-3, Blackwell Winter 2015 Mitglied von USF Tampa, Team 1-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G3
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 18
Insgesamt: 370
