Einleitung
If phone will not vibrate, vibrates slightly or vibrates sometimes, a faulty vibrator could be the issue.
Was du brauchst
Power off your device.
Remove the bottom cover by sliding it off.
Remove the SIM card.
Remove the four screws securing the bottom casing.
Two 3.0 mm Phillips #0 screws in the top left and right corners.
Two 2.0 mm Phillips #0 screws in the bottom left and right corners.
Use a plastic opening tool to pry open the bottom casing.
Remove the bottom casing by pulling it towards you.
Use the plastic opening tool to pry open the rear camera panel.
Remove both screws that are securing the back case.
One 4.0 mm Phillips #0 screw.
One 3.0 mm Phillips #0 screw.
Using both thumbs, gently push on the two bottom rear corners of the motherboard.
Gently and slowly pull the screen out from the front of the phone, while feeding the OEM reader contact through the opening.
Gently lift up the battery away from the edge of its housing.
Use the point end of the spudger to push the connection out of its housing.
Remove the two 3.0 mm Phillips #0 screws, that are securing the camera lens.
Pry the vibrator out of the housing with a spudger.
Using the tweezers, pull up on the connecting wires detaching the vibrator from the motherboard.
