Zum Hauptinhalt wechseln
HTC One X Plus Antenna Replacement
Was du brauchst
  1. HTC One X Plus Antenna Replacement, Antenna: Schritt 1, Bild 1 von 1
    • Power off your device.
    • Insert a pin, paper clip, or very small piece of metal into the hole next to the micro-SIM card holder to remove it.
    • The SIM card slot is located on the top edge of the device.
  2. HTC One X Plus Antenna Replacement: Schritt 2, Bild 1 von 3 HTC One X Plus Antenna Replacement: Schritt 2, Bild 2 von 3 HTC One X Plus Antenna Replacement: Schritt 2, Bild 3 von 3
    • Using the plastic opening tools, pry open the bottom of the device first.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached, use the suction cup tool to remove the screen completely from the black encasing.
  3. HTC One X Plus Antenna Replacement: Schritt 3, Bild 1 von 1
    • Now that the rear panel has been removed, use the metal tweezers to carefully remove the antenna.
    • The antenna is the loose black wire located to the right of the battery.
    • Using the metal tweezers, connect and install your new antenna, securing the antenna beneath the metal supports.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Jason Melo
483 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 3-3, Eyestone Fall 2015 Mitglied von USF Tampa, Team 3-3, Eyestone Fall 2015
USFT-EYESTONE-F15S3G3
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 5
Insgesamt: 655
