Einleitung
Use this guide to replace the motherboard on a HTC One X Plus cell phone with the appropriate tools listed.
Was du brauchst
Power off your device.
Insert a pin, paper clip, or very small piece of metal into the hole next to the micro sim card holder to remove it.
Using plastic opening tools, pry open the bottom of the device first.
You will hear clicking sounds as the sides of the device detach from the screen.
Once both sides are detached, use the suction cup tool to remove the screen completely from the black encasing.
Using a Philips head screw driver, remove the five 2.4mm screws that are pictured. Then remove the plastic cover.
Use the J000 Philips screw driver head to remove the screws as pictured.
Remove the PCB board and the antenna.
Disconnect the battery from the logic board.
Remove the battery by pulling upwards.
Disconnect the remaining two flex cables following the same procedure from Step 5.
Once these two flex cables have been disconnected, you may now remove the motherboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
