Einleitung
You may need to replace your screen if it is broken or cracked.
Was du brauchst
Power off your device.
Insert a pin, paper clip, or very small piece of metal in the hole next to the micro sim card holder to remove it.
Using plastic opening tools, pry open the bottom of the device first.
Once both sides are detached, use the suction cup tool to remove the screen completely from the black encasing.
Remove the five 2.4 mm screws using a Phillips #000 screwdriver.
Remove the plastic cover.
Use a Phillips #000 screwdriver to remove the two 3.4 mm screws.
Remove the PCB board and antenna.
Disconnect the battery's six pin connector from the motherboard.
Remove the battery by pulling it upwards.
Disconnect the screen from the digitizer.
Use a plastic opening tool to gently disconnect the screen from the digitizer.
Ein Kommentar
Man, this did nothing but break my International One X+. There were so many instructions missing.
