Zum Hauptinhalt wechseln
HTC One X Plus Screen Replacement
Was du brauchst
  1. HTC One X Plus Screen Replacement, Screen: Schritt 1, Bild 1 von 1
    • Power off your device.
    • Insert a pin, paper clip, or very small piece of metal in the hole next to the micro sim card holder to remove it.
    • The sim card slot is located on the top edge of the device.
  2. HTC One X Plus Screen Replacement: Schritt 2, Bild 1 von 3 HTC One X Plus Screen Replacement: Schritt 2, Bild 2 von 3 HTC One X Plus Screen Replacement: Schritt 2, Bild 3 von 3
    • Using plastic opening tools, pry open the bottom of the device first.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached, use the suction cup tool to remove the screen completely from the black encasing.
  3. HTC One X Plus Screen Replacement: Schritt 3, Bild 1 von 3 HTC One X Plus Screen Replacement: Schritt 3, Bild 2 von 3 HTC One X Plus Screen Replacement: Schritt 3, Bild 3 von 3
    • Remove the five 2.4 mm screws using a Phillips #000 screwdriver.
    • Remove the plastic cover.
  4. HTC One X Plus Screen Replacement: Schritt 4, Bild 1 von 3 HTC One X Plus Screen Replacement: Schritt 4, Bild 2 von 3 HTC One X Plus Screen Replacement: Schritt 4, Bild 3 von 3
    • Use a Phillips #000 screwdriver to remove the two 3.4 mm screws.
    • Remove the PCB board and antenna.
  5. HTC One X Plus Screen Replacement: Schritt 5, Bild 1 von 2 HTC One X Plus Screen Replacement: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use tweezers to disconnect the power button flex cable.
  6. HTC One X Plus Screen Replacement: Schritt 6, Bild 1 von 3 HTC One X Plus Screen Replacement: Schritt 6, Bild 2 von 3 HTC One X Plus Screen Replacement: Schritt 6, Bild 3 von 3
    • Disconnect the battery's six pin connector from the motherboard.
    • Remove the battery by pulling it upwards.
  7. HTC One X Plus Screen Replacement: Schritt 7, Bild 1 von 1
    • Disconnect the screen from the digitizer.
    • Use a plastic opening tool to gently disconnect the screen from the digitizer.
    • You may have to use heat to loosen adhesive securing the screen.
Abschluss
Jason Melo
483 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 3-3, Eyestone Fall 2015 Mitglied von USF Tampa, Team 3-3, Eyestone Fall 2015
USFT-EYESTONE-F15S3G3
3 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
Man, this did nothing but break my International One X+. There were so many instructions missing.
Garrett Reyman - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 10
Insgesamt: 1,851
