Was du brauchst
Flip the phone over to have the rear cover facing up.
The camera lens should be towards the top of the phone.
Slide the cover up, towards the top of phone, to unlock the battery cover.
Lift the cover off phone and remove it.
Use your finger to push the top of the battery downwards and lift the battery out of the phone.
In diesem Schritt verwendetes Werkzeug:Plastic Cards$2.99
Pry the frame open, releasing the eight plastic tabs around the edge of the frame, using the plastic opening tool.
Remove the single Phillips #0 screw that is securing the motherboard to the front case of the phone.
Pry the motherboard away from the front of the plastic case using a plastic opening tool.
Carefully lift the black lock to release the ribbon cable, using the plastic opening tool.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
