Zum Hauptinhalt wechseln
HTC Ozone LCD Display Replacement
Was du brauchst
  1. HTC Ozone LCD Display Replacement, Rear Battery Cover: Schritt 1, Bild 1 von 1
    • Flip the phone over to have the rear cover facing up.
    • The camera lens should be towards the top of the phone.
  2. HTC Ozone LCD Display Replacement: Schritt 2, Bild 1 von 2 HTC Ozone LCD Display Replacement: Schritt 2, Bild 2 von 2
    • Slide the cover up, towards the top of phone, to unlock the battery cover.
    • Lift the cover off phone and remove it.
  3. HTC Ozone LCD Display Replacement, Battery: Schritt 3, Bild 1 von 3 HTC Ozone LCD Display Replacement, Battery: Schritt 3, Bild 2 von 3 HTC Ozone LCD Display Replacement, Battery: Schritt 3, Bild 3 von 3
    • Use your finger to push the top of the battery downwards and lift the battery out of the phone.
  4. HTC Ozone LCD Display Replacement, Frame: Schritt 4, Bild 1 von 3 HTC Ozone LCD Display Replacement, Frame: Schritt 4, Bild 2 von 3 HTC Ozone LCD Display Replacement, Frame: Schritt 4, Bild 3 von 3
    • Remove the six Torx #5 screws that are securing the rear frame.
  5. HTC Ozone LCD Display Replacement: Schritt 5, Bild 1 von 3 HTC Ozone LCD Display Replacement: Schritt 5, Bild 2 von 3 HTC Ozone LCD Display Replacement: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    Kaufen
    • Pry the frame open, releasing the eight plastic tabs around the edge of the frame, using the plastic opening tool.
    • A plastic card can be used instead of the plastic opening tool.
  6. HTC Ozone LCD Display Replacement, Motherboard: Schritt 6, Bild 1 von 2 HTC Ozone LCD Display Replacement, Motherboard: Schritt 6, Bild 2 von 2
    • Remove the single Phillips #0 screw that is securing the motherboard to the front case of the phone.
  7. HTC Ozone LCD Display Replacement: Schritt 7, Bild 1 von 2 HTC Ozone LCD Display Replacement: Schritt 7, Bild 2 von 2
    • Pry the motherboard away from the front of the plastic case using a plastic opening tool.
    • Be careful not to break the ribbon cable when prying away the motherboard.
  8. HTC Ozone LCD Display Replacement: Schritt 8, Bild 1 von 3 HTC Ozone LCD Display Replacement: Schritt 8, Bild 2 von 3 HTC Ozone LCD Display Replacement: Schritt 8, Bild 3 von 3
    • Remove the plastic cover from the LCD display and the motherboard.
    • The Motherboard and the LCD are still attached together.
  9. HTC Ozone LCD Display Replacement, LCD Display: Schritt 9, Bild 1 von 2 HTC Ozone LCD Display Replacement, LCD Display: Schritt 9, Bild 2 von 2
    • Remove the gray tape securing the ribbon cable.
  10. HTC Ozone LCD Display Replacement: Schritt 10, Bild 1 von 1
    • Remove the yellow tape securing the connector lock.
  11. HTC Ozone LCD Display Replacement: Schritt 11, Bild 1 von 2 HTC Ozone LCD Display Replacement: Schritt 11, Bild 2 von 2
    • Carefully lift the black lock to release the ribbon cable, using the plastic opening tool.
  12. HTC Ozone LCD Display Replacement: Schritt 12, Bild 1 von 1
    • Pull the ribbon cable upwards, disconnecting it from the Motherboard.
  13. HTC Ozone LCD Display Replacement: Schritt 13, Bild 1 von 1
    • Lift the Motherboard away from the LCD display.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Marco Jokada
247 Reputation
6 Anleitungen geschrieben
CSU Los Angeles, Team 1-2, Nelson Spring 2011 Mitglied von CSU Los Angeles, Team 1-2, Nelson Spring 2011
CSULA-NELSON-S11S1G2
5 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 2,108
