Zum Hauptinhalt wechseln
HTC Ozone Motherboard Replacement
Was du brauchst
  1. HTC Ozone Motherboard Replacement, Rear Battery Cover: Schritt 1, Bild 1 von 1
    • Flip the phone over to have the rear cover facing up.
    • The camera lens should be towards the top of the phone.
  2. HTC Ozone Motherboard Replacement: Schritt 2, Bild 1 von 2 HTC Ozone Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Slide the cover up, towards the top of phone, to unlock the battery cover.
    • Lift the cover off phone and remove it.
  3. HTC Ozone Motherboard Replacement, Battery: Schritt 3, Bild 1 von 3 HTC Ozone Motherboard Replacement, Battery: Schritt 3, Bild 2 von 3 HTC Ozone Motherboard Replacement, Battery: Schritt 3, Bild 3 von 3
    • Use your finger to push the top of the battery downwards and lift the battery out of the phone.
  4. HTC Ozone Motherboard Replacement, Frame: Schritt 4, Bild 1 von 3 HTC Ozone Motherboard Replacement, Frame: Schritt 4, Bild 2 von 3 HTC Ozone Motherboard Replacement, Frame: Schritt 4, Bild 3 von 3
    • Remove the six Torx #5 screws that are securing the rear frame.
  5. HTC Ozone Motherboard Replacement: Schritt 5, Bild 1 von 3 HTC Ozone Motherboard Replacement: Schritt 5, Bild 2 von 3 HTC Ozone Motherboard Replacement: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    Kaufen
    • Pry the frame open, releasing the eight plastic tabs around the edge of the frame, using the plastic opening tool.
    • A plastic card can be used instead of the plastic opening tool.
  6. HTC Ozone Motherboard Replacement, Motherboard: Schritt 6, Bild 1 von 2 HTC Ozone Motherboard Replacement, Motherboard: Schritt 6, Bild 2 von 2
    • Remove the single Phillips #0 screw that is securing the motherboard to the front case of the phone.
  7. HTC Ozone Motherboard Replacement: Schritt 7, Bild 1 von 2 HTC Ozone Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Pry the motherboard away from the front of the plastic case using a plastic opening tool.
    • Be careful not to break the ribbon cable when prying away the motherboard.
  8. HTC Ozone Motherboard Replacement: Schritt 8, Bild 1 von 3 HTC Ozone Motherboard Replacement: Schritt 8, Bild 2 von 3 HTC Ozone Motherboard Replacement: Schritt 8, Bild 3 von 3
    • Remove the plastic cover from the LCD display and the motherboard.
    • The Motherboard and the LCD are still attached together.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Marco Jokada
247 Reputation
6 Anleitungen geschrieben
CSU Los Angeles, Team 1-2, Nelson Spring 2011 Mitglied von CSU Los Angeles, Team 1-2, Nelson Spring 2011
CSULA-NELSON-S11S1G2
5 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Where can I buy/find/get this motherboard? I have been looking for one for over a year now, thanks
Walt - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 1,529
