Zum Hauptinhalt wechseln
HTC Radar 4G Touch Digitizer Replacement
Was du brauchst
  1. HTC Radar 4G Touch Digitizer Replacement, Touch Digitizer: Schritt 1, Bild 1 von 2 HTC Radar 4G Touch Digitizer Replacement, Touch Digitizer: Schritt 1, Bild 2 von 2
    • Slide the lower plastic panel off of the phone.
    • Remove the four screws from the white plastic cover of the phone using the T5 Torx screwdriver.
    • Remove the two black screws from the silver frame.
  2. HTC Radar 4G Touch Digitizer Replacement: Schritt 2, Bild 1 von 1
    • Remove the back cover by pressing on the back of the motherboard lightly and pulling the screen out carefully.
  3. HTC Radar 4G Touch Digitizer Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery from the phone using a fingernail or an opening pick.
  4. HTC Radar 4G Touch Digitizer Replacement: Schritt 4, Bild 1 von 1
    • Remove the three screws using a screwdriver.
    • Remove the plastic frame.
  5. HTC Radar 4G Touch Digitizer Replacement: Schritt 5, Bild 1 von 3 HTC Radar 4G Touch Digitizer Replacement: Schritt 5, Bild 2 von 3 HTC Radar 4G Touch Digitizer Replacement: Schritt 5, Bild 3 von 3
    • Remove the upper board and motherboard from the phone using an opening tool.
    • The regular black nylon spudger should be used whenever possible, especially around motherboards.
  6. HTC Radar 4G Touch Digitizer Replacement: Schritt 6, Bild 1 von 2 HTC Radar 4G Touch Digitizer Replacement: Schritt 6, Bild 2 von 2
    • Use your hands to remove the touch digitizer.
Abschluss
Kevin Guerra
101 Reputation
1 Anleitung geschrieben
Texas Tech, Team 12-5, Bennett Fall 2016 Mitglied von Texas Tech, Team 12-5, Bennett Fall 2016
TTU-BENNETT-F16S12G5
4 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 293
