Einleitung
You will disassemble the phone in order to take the battery out and replace it.
Was du brauchst
Lift up the blue flaps underneath the battery.
Lift up the black flap at the top of the phone.
Lift up the black flap at the bottom of the phone.
Remove all 4 screws.
Carefully remove the motherboard with your hands.
Pry the back plastic casing off with your hands.
Remove the screws.
Use a metal spudger to remove the battery.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
