Zum Hauptinhalt wechseln
HTC Rhyme Battery Replacement
Was du brauchst
  1. HTC Rhyme Battery Replacement, Removing Back Cover: Schritt 1, Bild 1 von 2 HTC Rhyme Battery Replacement, Removing Back Cover: Schritt 1, Bild 2 von 2
    • Slide the bottom back cover off of the phone.
  2. HTC Rhyme Battery Replacement: Schritt 2, Bild 1 von 1
    • Locate the four screws on the plastic cover and unscrew them.
  3. HTC Rhyme Battery Replacement: Schritt 3, Bild 1 von 2 HTC Rhyme Battery Replacement: Schritt 3, Bild 2 von 2
    • Pry the sticker off from the sides.
    • You can use a metal spudger to do this.
    • Peel the sticker off with your hands.
  4. HTC Rhyme Battery Replacement, Remove the plastic cover: Schritt 4, Bild 1 von 1
    • Remove the plastic cover using your hands.
  5. HTC Rhyme Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove the yellow ribbon.
  6. HTC Rhyme Battery Replacement: Schritt 6, Bild 1 von 3 HTC Rhyme Battery Replacement: Schritt 6, Bild 2 von 3 HTC Rhyme Battery Replacement: Schritt 6, Bild 3 von 3
    • Lift up the blue flaps underneath the battery.
    • Lift up the black flap at the top of the phone.
    • Lift up the black flap at the bottom of the phone.
  7. HTC Rhyme Battery Replacement, Remove the Motherboard: Schritt 7, Bild 1 von 2 HTC Rhyme Battery Replacement, Remove the Motherboard: Schritt 7, Bild 2 von 2
    • Remove all 4 screws.
    • Carefully remove the motherboard with your hands.
  8. HTC Rhyme Battery Replacement, Removing the Back Plastic Casing: Schritt 8, Bild 1 von 3 HTC Rhyme Battery Replacement, Removing the Back Plastic Casing: Schritt 8, Bild 2 von 3 HTC Rhyme Battery Replacement, Removing the Back Plastic Casing: Schritt 8, Bild 3 von 3
    • Pry the back plastic casing off with your hands.
  9. HTC Rhyme Battery Replacement, Removing the Battery: Schritt 9, Bild 1 von 3 HTC Rhyme Battery Replacement, Removing the Battery: Schritt 9, Bild 2 von 3 HTC Rhyme Battery Replacement, Removing the Battery: Schritt 9, Bild 3 von 3
    • Remove the screws.
    • Use a metal spudger to remove the battery.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 9-6, Leahy Fall 2014 Mitglied von USF Tampa, Team 9-6, Leahy Fall 2014
USFT-LEAHY-F14S9G6
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 12
Insgesamt: 5,049
