Was du brauchst
Using a metal spudger, pry up the plastic piece covering the motherboard, and remove the sticker.
Use a Philip #0 screwdriver to remove the four screws of the plastic covering the motherboard.
Using your thumb, push the flap up on the top.
Using your thumb, push the flap up on the bottom of the motherboard.
Using a Phillips #00 screwdriver, unscrew the four screws in each corner of the motherboard.
Using tweezers, lift the secondary motherboard from the base of the phone.
The speaker is located on the back of the board.
