Zum Hauptinhalt wechseln
  1. Slide the bottom back casing off, pulling down. Slide the bottom back casing off, pulling down.
    • Slide the bottom back casing off, pulling down.
  2. Using the plastic tool, pry underneath the top plastic cover. Using the plastic tool, pry underneath the top plastic cover.
    • Using the plastic tool, pry underneath the top plastic cover.
  3. Using a metal spudger, pry up the plastic piece covering the motherboard, and remove the sticker. Using a metal spudger, pry up the plastic piece covering the motherboard, and remove the sticker.
    • Using a metal spudger, pry up the plastic piece covering the motherboard, and remove the sticker.
  4. Use a Philip #0 screwdriver to remove the four screws of the plastic covering the motherboard. Use a Philip #0 screwdriver to remove the four screws of the plastic covering the motherboard.
    • Use a Philip #0 screwdriver to remove the four screws of the plastic covering the motherboard.
  5. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  6. Using tweezers, remove the yellow ribbon by gently pulling on it.
    • Using tweezers, remove the yellow ribbon by gently pulling on it.
  7. Using the plastic tweezers, gently lift the blue flaps up. Using the plastic tweezers, gently lift the blue flaps up.
    • Using the plastic tweezers, gently lift the blue flaps up.
  8. Using your thumb, push the flap up on the top. Using your thumb, push the flap up on the bottom of the motherboard.
    • Using your thumb, push the flap up on the top.
    • Using your thumb, push the flap up on the bottom of the motherboard.
  9. Using a Phillips #00 screwdriver, unscrew the four screws in each corner of the motherboard. Using a Phillips #00 screwdriver, unscrew the four screws in each corner of the motherboard.
    • Using a Phillips #00 screwdriver, unscrew the four screws in each corner of the motherboard.
  10. Carefully remove the motherboard from the base of the phone.
    • Carefully remove the motherboard from the base of the phone.
  11. Gently push the base of the phone from the frame. Gently push the base of the phone from the frame. Gently push the base of the phone from the frame.
    • Gently push the base of the phone from the frame.
  12. Using the metal spudger, remove the battery from the base. Using the metal spudger, remove the battery from the base.
    • Using the metal spudger, remove the battery from the base.
  13. Using tweezers, lift the secondary motherboard from the base of the phone. The speaker is located on the back of the board.
    • Using tweezers, lift the secondary motherboard from the base of the phone.
    • The speaker is located on the back of the board.
Abschluss
Kelsey Harris
121 Reputation
1 Anleitung geschrieben
USF Tampa, Team 9-6, Leahy Fall 2014 Mitglied von USF Tampa, Team 9-6, Leahy Fall 2014
USFT-LEAHY-F14S9G6
3 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 273
