Zum Hauptinhalt wechseln
HTC Rhyme charging port Replacement
Was du brauchst
  1. HTC Rhyme charging port Replacement, Charging Port: Schritt 1, Bild 1 von 2 HTC Rhyme charging port Replacement, Charging Port: Schritt 1, Bild 2 von 2
    • Image of the front and back of the HTC Rhyme.
  2. HTC Rhyme charging port Replacement: Schritt 2, Bild 1 von 3 HTC Rhyme charging port Replacement: Schritt 2, Bild 2 von 3 HTC Rhyme charging port Replacement: Schritt 2, Bild 3 von 3
    • Remove the back cover by pulling down on the lower half.
  3. HTC Rhyme charging port Replacement: Schritt 3, Bild 1 von 3 HTC Rhyme charging port Replacement: Schritt 3, Bild 2 von 3 HTC Rhyme charging port Replacement: Schritt 3, Bild 3 von 3
    • Use a T5 to remove the five highlighted screws in the image.
  4. HTC Rhyme charging port Replacement: Schritt 4, Bild 1 von 2 HTC Rhyme charging port Replacement: Schritt 4, Bild 2 von 2
    • Once the screws are removed, slide the back cover off of the phone.
  5. HTC Rhyme charging port Replacement: Schritt 5, Bild 1 von 3 HTC Rhyme charging port Replacement: Schritt 5, Bild 2 von 3 HTC Rhyme charging port Replacement: Schritt 5, Bild 3 von 3
    • Remove the two screws highlighted in the image with a Phillips screwdriver.
  6. HTC Rhyme charging port Replacement: Schritt 6, Bild 1 von 2 HTC Rhyme charging port Replacement: Schritt 6, Bild 2 von 2
    • Push off the small silver piece resting above the charging port.
  7. HTC Rhyme charging port Replacement: Schritt 7, Bild 1 von 3 HTC Rhyme charging port Replacement: Schritt 7, Bild 2 von 3 HTC Rhyme charging port Replacement: Schritt 7, Bild 3 von 3
    • Disconnect the black cable on the upper right side of the motherboard.
  8. HTC Rhyme charging port Replacement: Schritt 8, Bild 1 von 3 HTC Rhyme charging port Replacement: Schritt 8, Bild 2 von 3 HTC Rhyme charging port Replacement: Schritt 8, Bild 3 von 3
    • Disconnect the green cables in the upper center section of the motherboard.
  9. HTC Rhyme charging port Replacement: Schritt 9, Bild 1 von 3 HTC Rhyme charging port Replacement: Schritt 9, Bild 2 von 3 HTC Rhyme charging port Replacement: Schritt 9, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Disconnect the yellow cable by gently pulling on it with tweezers.
    • When assembling, use your fingers to reconnect the wire.
  10. HTC Rhyme charging port Replacement: Schritt 10, Bild 1 von 3 HTC Rhyme charging port Replacement: Schritt 10, Bild 2 von 3 HTC Rhyme charging port Replacement: Schritt 10, Bild 3 von 3
    • Disconnect the white cord on the lower left side of the motherboard.
  11. HTC Rhyme charging port Replacement: Schritt 11, Bild 1 von 3 HTC Rhyme charging port Replacement: Schritt 11, Bild 2 von 3 HTC Rhyme charging port Replacement: Schritt 11, Bild 3 von 3
    • Gently remove the motherboard with your hand.
  12. HTC Rhyme charging port Replacement: Schritt 12, Bild 1 von 3 HTC Rhyme charging port Replacement: Schritt 12, Bild 2 von 3 HTC Rhyme charging port Replacement: Schritt 12, Bild 3 von 3
    • Desolder and remove the charging port on the motherboard.
    • Solder a new charging port onto the pads where the previous charging port had been.
  13. HTC Rhyme charging port Replacement: Schritt 13, Bild 1 von 3 HTC Rhyme charging port Replacement: Schritt 13, Bild 2 von 3 HTC Rhyme charging port Replacement: Schritt 13, Bild 3 von 3
    • Follow steps 11 through 1, to put the phone back together.
Abschluss
Rebecca Chapman
104 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 287
