Zum Hauptinhalt wechseln
HTC SMT 6175 Keyboard Replacement
Was du brauchst
  1. HTC SMT 6175 Keyboard Replacement, Back Case: Schritt 1, Bild 1 von 1
    • First, flip the phone over so that the back is facing upwards.
  2. HTC SMT 6175 Keyboard Replacement: Schritt 2, Bild 1 von 2 HTC SMT 6175 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Using both thumbs, push the back side of the phone's exterior up and remove the front face of the phone.
  3. HTC SMT 6175 Keyboard Replacement, Battery: Schritt 3, Bild 1 von 2 HTC SMT 6175 Keyboard Replacement, Battery: Schritt 3, Bild 2 von 2
    • Insert your finger or a pry tool into the slot above the battery. Remove it and set aside.
  4. HTC SMT 6175 Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 2 HTC SMT 6175 Keyboard Replacement, Keyboard: Schritt 4, Bild 2 von 2
    • To remove the back casing inside the phone, remove the six screws around the perimeter.
  5. HTC SMT 6175 Keyboard Replacement: Schritt 5, Bild 1 von 2 HTC SMT 6175 Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Carefully pull off the back casing.
    • This step may be difficult. Start pulling the back out from the front shell. As it starts to lift up, move the phone side-to-side until the whole back is free.
  6. HTC SMT 6175 Keyboard Replacement: Schritt 6, Bild 1 von 2 HTC SMT 6175 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Remove the top screw.
    • Be CAREFUL, because the LCD screen is attached to the front side of the motherboard by a flexible ribbon cable.
  7. HTC SMT 6175 Keyboard Replacement, QWERTY Keyboard: Schritt 7, Bild 1 von 3 HTC SMT 6175 Keyboard Replacement, QWERTY Keyboard: Schritt 7, Bild 2 von 3 HTC SMT 6175 Keyboard Replacement, QWERTY Keyboard: Schritt 7, Bild 3 von 3
    • Pull the plastic keyboard away from the front case.
  8. HTC SMT 6175 Keyboard Replacement, Navigation Keys: Schritt 8, Bild 1 von 3 HTC SMT 6175 Keyboard Replacement, Navigation Keys: Schritt 8, Bild 2 von 3 HTC SMT 6175 Keyboard Replacement, Navigation Keys: Schritt 8, Bild 3 von 3
    • To remove the navigation keys on the front of the phone, remove the four screws securing the navigation keys using a Phillips screwdriver.
    • Remove the navigation keys from the front of the phone.
    • They should pop out as a unit.
Abschluss
Luke Plewa
116 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 25-29, Garner Spring 2011 Mitglied von Cal Poly, Team 25-29, Garner Spring 2011
CPSU-GARNER-S11S25G29
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 11
Insgesamt: 1,673
