Zum Hauptinhalt wechseln
HTC Sensation / 4G / Pyramid - Touch Screen / Digitizer Replacement
Was du brauchst
Einführungsvideo
  1. HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement, Touch Screen / Digitizer: Schritt 1, Bild 1 von 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement, Touch Screen / Digitizer: Schritt 1, Bild 2 von 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement, Touch Screen / Digitizer: Schritt 1, Bild 3 von 3
    • Unscrew 8x screws and remove the back cover using a plastic tool.
  2. HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: Schritt 2, Bild 1 von 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: Schritt 2, Bild 2 von 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: Schritt 2, Bild 3 von 3
    • Disconnect the LCD display cable and the menu buttons cable.
    • There are another two cable connector between the main board and the additional upper board.
  3. HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: Schritt 3, Bild 1 von 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: Schritt 3, Bild 2 von 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: Schritt 3, Bild 3 von 3
    • In case to remove the upper board, unscrew the screw and release the power button flex cable and the volume up/down flex cable.
    • In another side of the board is the touchscreen flex cable connector.
  4. HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: Schritt 4, Bild 1 von 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: Schritt 4, Bild 2 von 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: Schritt 4, Bild 3 von 3
    • Use hot air to warm the touchscreen.
    • With a plastic tool start to separate the touchscreen.
    • Gently release the menu flex cable from the touch screen.
  5. HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: Schritt 5, Bild 1 von 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: Schritt 5, Bild 2 von 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: Schritt 5, Bild 3 von 3
    • The touchscreen flex cable go between the LCD display and the upper case / housing.
    • Again use a plastic tool and hot air to free up the cable.
    • Work carefully to avoid breaking the display.
  6. HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: Schritt 6, Bild 1 von 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: Schritt 6, Bild 2 von 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: Schritt 6, Bild 3 von 3
    • I use toothpicks and hot air to make place for the cable of the new spare part.
  7. HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: Schritt 7, Bild 1 von 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: Schritt 7, Bild 2 von 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: Schritt 7, Bild 3 von 3
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
ZFix
191.368 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
321 Mitglieder
1.468 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 14
Insgesamt: 4,099
