Zum Hauptinhalt wechseln
HTC Surround SD Card Replacement
Was du brauchst
  1. HTC Surround SD Card Replacement, Back Case: Schritt 1, Bild 1 von 2 HTC Surround SD Card Replacement, Back Case: Schritt 1, Bild 2 von 2
    • Remove the back cover of the device to access the internal components of the HTC 7 Surround.
    • To remove the back cover, use the circular hole to lift up the cover while holding the front of the device down.
  2. HTC Surround SD Card Replacement: Schritt 2, Bild 1 von 3 HTC Surround SD Card Replacement: Schritt 2, Bild 2 von 3 HTC Surround SD Card Replacement: Schritt 2, Bild 3 von 3
    • Using a Phillips #00 screwdriver, remove the screws as directed.
  3. HTC Surround SD Card Replacement: Schritt 3, Bild 1 von 1
    • Separate the screen and back cover with the opening tool.
  4. HTC Surround SD Card Replacement, SD Card: Schritt 4, Bild 1 von 3 HTC Surround SD Card Replacement, SD Card: Schritt 4, Bild 2 von 3 HTC Surround SD Card Replacement, SD Card: Schritt 4, Bild 3 von 3
    • Look at the bottom right hand corner of the device and remove the silver tape covering the SD card slot with your fingers.
    • Insert the plastic opening tool directly underneath the orange surface below the SIM card until its removed from the surface of the device.
  5. HTC Surround SD Card Replacement: Schritt 5, Bild 1 von 2 HTC Surround SD Card Replacement: Schritt 5, Bild 2 von 2
    • To get to the attachment that the SD/SIM card is attached to; insert the plastic opening tool underneath the lower motherboard until it is removed from the bottom half of the device.
    • You will notice the SD/SIM card is attached to the lower motherboard by a yellow piece of tape. Remove the tape from the back of motherboard with your fingers.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 16
Letzte 30 Tage: 25
Insgesamt: 226
