Zum Hauptinhalt wechseln
HTC Thunderbolt Motherboard Replacement
Was du brauchst
  1. HTC Thunderbolt Motherboard Replacement, Rear Panel: Schritt 1, Bild 1 von 1
    • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
    • Gently pry up on the rear panel around the edges until it is loose.
  2. HTC Thunderbolt Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Lift and remove the rear panel.
  3. HTC Thunderbolt Motherboard Replacement, Battery: Schritt 3, Bild 1 von 2 HTC Thunderbolt Motherboard Replacement, Battery: Schritt 3, Bild 2 von 2
    • Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
    • Remove the battery from the inner frame.
  4. HTC Thunderbolt Motherboard Replacement, MicroSD Card: Schritt 4, Bild 1 von 2 HTC Thunderbolt Motherboard Replacement, MicroSD Card: Schritt 4, Bild 2 von 2
    • Use your finger to push the MicroSD card in towards the top of the phone, allowing it to be released from the casing.
  5. HTC Thunderbolt Motherboard Replacement: Schritt 5, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use tweezers to grab onto the MicroSD card and carefully remove it from the casing.
  6. HTC Thunderbolt Motherboard Replacement, Rear Frame: Schritt 6, Bild 1 von 1
    • Remove the six Phillips screws from the perimeter of the rear frame.
    • By removing the screw with the "void" sticker on it, your Thunderbolt will no longer be covered under warranty.
  7. HTC Thunderbolt Motherboard Replacement: Schritt 7, Bild 1 von 2 HTC Thunderbolt Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Insert the plastic opening tool into the bottom of the phone underneath the soft keys.
    • Gently pry up on the plastic cover by sliding the plastic opening tool across the bottom of the phone.
    • Remove the plastic cover.
    • The plastic cover will have adhesive on it making it difficult to remove.
  8. HTC Thunderbolt Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Remove the two Phillips screws where the plastic cover was.
  9. HTC Thunderbolt Motherboard Replacement: Schritt 9, Bild 1 von 2 HTC Thunderbolt Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Insert the plastic opening tool in between the screen and the frame on the side of the phone.
    • Slowly slide the the plastic opening tool along the side of the phone until the screen begins to separate from the frame.
    • Do the same for the opposite side of the phone.
  10. HTC Thunderbolt Motherboard Replacement: Schritt 10, Bild 1 von 3 HTC Thunderbolt Motherboard Replacement: Schritt 10, Bild 2 von 3 HTC Thunderbolt Motherboard Replacement: Schritt 10, Bild 3 von 3
    • Carefully separate the screen and phone from the rear frame, starting from the bottom.
    • Gently pull down on the phone and screen to fully separate it from the rear frame.
  11. HTC Thunderbolt Motherboard Replacement, LCD/Screen: Schritt 11, Bild 1 von 2 HTC Thunderbolt Motherboard Replacement, LCD/Screen: Schritt 11, Bild 2 von 2
    Kaufen
    • Using the tip of an plastic opening tool flip up the tab holding the capacitive button ribbon cable.
    • Be careful opening these tabs as they are very easy to break.
    • Use a pair of tweezers to pull the capacitive button cable out of its socket.
  12. HTC Thunderbolt Motherboard Replacement: Schritt 12, Bild 1 von 2 HTC Thunderbolt Motherboard Replacement: Schritt 12, Bild 2 von 2
    • Lifting from the side where the ribbon was disconnected, flip over the motherboard.
    • Remove the black tape covering the tabs connecting the motherboard and LCD.
  13. HTC Thunderbolt Motherboard Replacement: Schritt 13, Bild 1 von 1
    • Using the plastic opening tool pop up the two tabs connecting the LCD and motherboard.
  14. HTC Thunderbolt Motherboard Replacement: Schritt 14, Bild 1 von 2 HTC Thunderbolt Motherboard Replacement: Schritt 14, Bild 2 von 2
    • Once the tabs have been popped up, slowly pull the two pieces away from each other.
    • If there is resistance pulling apart the phone then a ribbon or tab has not been disconnected properly/completely.
  15. HTC Thunderbolt Motherboard Replacement, Motherboard: Schritt 15, Bild 1 von 1
    • The motherboard should now be completely disconnected
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Vanessa
60 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 19-45, Regan Winter 2013 Mitglied von Cal Poly, Team 19-45, Regan Winter 2013
CPSU-REGAN-W13S19G45
4 Mitglieder
24 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 13
Insgesamt: 1,755
