Einleitung
Warning: Always be sure you are grounded whenever handling any of the circuit or logic boards.
Was du brauchst
Remove the four screws in the corners of the phone using the T5 Torx screwdriver.
Use the plastic opening tool to remove the front panel from the phone.
Unplug the front button cable from the inside of the phone.
Remove the two screws from the back of the front panel using the Phillips #00 screwdriver.
Remove the small circuit board by gently pushing on the center button on the front of the phone.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
I need the keypad flex cable. Where to buy. Please guide smahapatra2012@gmail.com
