Einleitung
If your HTC Touch Pro 2 Camera isn’t turning on, a possible issue may be with the camera lens. Follow this guide to learn how to replace your HTC Touch Pro 2 Camera. After the lens is replaced the quality of picture should be restored to its original state. This guide requires a T5 screwdriver and some tweezers.
Use caution when replacing the lens if the glass of the lens is shattered to avoid injury.
Was du brauchst
Apply pressure and slide upward to remove back cover.
Lift the back cover up away from the phone.
Lift battery upward on the upper right-hand side to remove it.
Check the battery to make sure there's no bent corners
Remove the four screws from the corners of the phone using a T5 Torx screwdriver.
Use the tweezers to pull the camera cover up and away from the phone. Repeat for the camera underneath.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
