Was du brauchst
Apply pressure and slide upward to remove back cover.
Lift the back cover up away from the phone.
Lift battery upward on the upper right-hand side to remove it.
Check the battery to make sure there's no bent corners
Using a T5 screwdriver, remove the four screws in corners as shown.
Lift the top portion of the rear case.
Using an IfixIt Plastic Tool, detach the plastic casing from the keyboard. This may require some force.
Using a spudger or other thin tool, carefully pry up ZIF connectors as shown. This will allow the black ribbons to detach from the keyboard.
Slide the two parts away from each other so that the black ribbons slide through the slots and you will now have housing into two parts.
Peel off the yellow ribbon shown slowly.
Unscrew the fours screws shown in red squares (two in each square) using a 00 screwdriver.
After the screws are out, you will be able to easily take off the small metal pieces circled in red. Please do so.
Lift ZIF connectors up.
Carefully lift keyboard frame away from display screen.
You now have the keyboard detached.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
