Was du brauchst
Apply pressure and slide upward to remove back cover.
Lift the back cover up away from the phone.
Lift battery upward on the upper right-hand side to remove it.
Check the battery to make sure there's no bent corners
Insert stylus into black slot and gentle pry SIM card out a little bit.
Slide out SIM card rest of the way with your finger.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
