Zum Hauptinhalt wechseln
HTC Touch Pro CDMA Keyboard Replacement
Was du brauchst
  1. HTC Touch Pro CDMA Keyboard Replacement, Battery: Schritt 1, Bild 1 von 2 HTC Touch Pro CDMA Keyboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • First, gently press on the back plate and push down toward the camera.
  2. HTC Touch Pro CDMA Keyboard Replacement: Schritt 2, Bild 1 von 2 HTC Touch Pro CDMA Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Use your finger to lift up the edge of the battery.
  3. HTC Touch Pro CDMA Keyboard Replacement, USB Logic Board: Schritt 3, Bild 1 von 1
    • Remove the 4 screws using the T6 screw driver.
  4. HTC Touch Pro CDMA Keyboard Replacement: Schritt 4, Bild 1 von 2 HTC Touch Pro CDMA Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Lift the plastic cover near the memory card slot.
  5. HTC Touch Pro CDMA Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Remove the two Phillips #00 screws from the backside of the screen.
  6. HTC Touch Pro CDMA Keyboard Replacement: Schritt 6, Bild 1 von 2 HTC Touch Pro CDMA Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Insert a spudger or a plastic opening tool into the seam on the side of the phone.
    • Gently pry apart the two halves of the phone.
  7. HTC Touch Pro CDMA Keyboard Replacement: Schritt 7, Bild 1 von 2 HTC Touch Pro CDMA Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Gently unplug the connectors.
    • Remove the screws with a 00 Phillips-head screwdriver.
  8. HTC Touch Pro CDMA Keyboard Replacement: Schritt 8, Bild 1 von 2 HTC Touch Pro CDMA Keyboard Replacement: Schritt 8, Bild 2 von 2
    • Gently lift the motherboard up using a nylon spudger.
    • BE AWARE OF THE ANTENNA.
  9. HTC Touch Pro CDMA Keyboard Replacement, Keyboard: Schritt 9, Bild 1 von 2 HTC Touch Pro CDMA Keyboard Replacement, Keyboard: Schritt 9, Bild 2 von 2
    • Remove the 4 screws circled in red using a 00 Phillips-head screwdriver.
Abschluss
Zhaowei Zhang
133 Reputation
4 Anleitungen geschrieben
CSU Los Angeles, Team 1-6, Nelson Spring 2011 Mitglied von CSU Los Angeles, Team 1-6, Nelson Spring 2011
CSULA-NELSON-S11S1G6
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 2,060
