Einleitung
The HTC Vive's midframe can crack if the device receives a major drop. This guide will show you how to replace the Vive's midframe.
Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
Slide the HTC panel covering the cables forward, away from the Vive.
Gently pull on each of the four connectors to remove the sound and Three-in-One cables.
Undo the hook and loop tape on the straps.
Slide the ends of the straps through the hinge loops.
Pull the facerest cushion off away from the Vive, separating the hook and loop tape.
Use a T6 Torx Screwdriver to remove either of the two 12mm hinge screws holding the two hinges in place.
Allow the hinge to fall away once the screw is removed.
Repeat for the opposite side.
Orient the Vive so that the camera is facing towards you and the connector ports are facing upwards, as in the photos.
Use a plastic opening tool to gently pry up the left side of the outer sheath.
If the left sheath is glued down, slide your plastic opening tool along the middle seam to break the bond.
Slide the left side of the sheath outwards.
Slide a plastic opening tool underneath the right side of the sheath to remove any remaining glue.
Using the plastic opening tool, pry the right side of the sheath upwards slightly.
Using your hands, slide the right side of the sheath outwards.
Remove the five 4mm Philips #00 screws holding the sensor array to the motherboard.
Remove the two 4mm Philips #00 screws holding the sensor array to the midframe.
Using a pair of ESD safe tweezers, gently pull the four ribbon cables out horizontally from the sensor array.
Lift the sensor array away from the rest of the Vive until the camera cable tugs back and hold it in place.
Disconnect the camera by lifting its ribbon cable up and away from the motherboard using a pair of ESD safe tweezers.
Lift the sensor array upwards away from the motherboard to separate the array from the device fully.
Loosen the three ribbon cables that are attached to the motherboard by grabbing the tabs on the side of the ribbon cables' connectors and pulling gently outwards.
Fully detach the same three ribbon cables by grabbing each cable with tweezers and sliding them outwards horizontally.
Pivot the top of the motherboard outwards until it has cleared the top of the plastic housing.
Pull the motherboard up and away from the plastic housing, away from the two hooks.
Grab the tabs on the side of the ribbon cable's connector and pull gently outwards to loosen it.
Remove the ribbon cable for the power button by grabbing the cable with tweezers and sliding it outwards horizontally.
Remove the four 4mm #00 Philips screws by the nose rest holding the midframe to the eyepiece assembly.
Remove the four 4mm #00 Philips screws on the top of the device, directly across from the four by the nose.
With one hand on the midframe and the other on the eyepiece assembly, pull the two parts away from each other.
Ein weiterer Nutzer hat diese Anleitung absolviert.
