Zum Hauptinhalt wechseln
HTC Vive Pro 2 Head Strap Replacement
Was du brauchst
    1. HTC Vive Pro 2 Head Strap Replacement, Reposition the head strap: Schritt 1, Bild 1 von 2 HTC Vive Pro 2 Head Strap Replacement, Reposition the head strap: Schritt 1, Bild 2 von 2
      • Rotate the head strap forward as far as it will go.
      Frag FixBot
      Kommentar hinzufügen
    2. HTC Vive Pro 2 Head Strap Replacement, Unplug the All-In-One Cable: Schritt 2, Bild 1 von 2 HTC Vive Pro 2 Head Strap Replacement, Unplug the All-In-One Cable: Schritt 2, Bild 2 von 2
      • Unplug the All-In-One Cable from your headset.
      Frag FixBot
    3. HTC Vive Pro 2 Head Strap Replacement, Remove the All-In-One Cable: Schritt 3, Bild 1 von 3 HTC Vive Pro 2 Head Strap Replacement, Remove the All-In-One Cable: Schritt 3, Bild 2 von 3 HTC Vive Pro 2 Head Strap Replacement, Remove the All-In-One Cable: Schritt 3, Bild 3 von 3
      • Remove the All-In-One Cable from the cable guides along the left side of the head strap.
      • During reassembly, connect the All-In-One Cable to the headset before routing it through the cable guides. This will ensure it has the right amount of slack.
      Frag FixBot
    1. HTC Vive Pro 2 Head Strap Replacement, Remove the top strap: Schritt 4, Bild 1 von 2 HTC Vive Pro 2 Head Strap Replacement, Remove the top strap: Schritt 4, Bild 2 von 2
      • Separate the top strap from itself where the Velcro secures it.
      Frag FixBot
    2. HTC Vive Pro 2 Head Strap Replacement: Schritt 5, Bild 1 von 3 HTC Vive Pro 2 Head Strap Replacement: Schritt 5, Bild 2 von 3 HTC Vive Pro 2 Head Strap Replacement: Schritt 5, Bild 3 von 3
      • Peel back the Velcro securing the rear of the top strap.
      • Feed the top strap out through the head strap to partially remove it.
      Frag FixBot
    3. HTC Vive Pro 2 Head Strap Replacement: Schritt 6, Bild 1 von 3 HTC Vive Pro 2 Head Strap Replacement: Schritt 6, Bild 2 von 3 HTC Vive Pro 2 Head Strap Replacement: Schritt 6, Bild 3 von 3
      • Feed the top strap through the clip near the front of headset to fully remove it.
      Frag FixBot
    1. HTC Vive Pro 2 Head Strap Replacement, Remove the front side foam pads: Schritt 7, Bild 1 von 3 HTC Vive Pro 2 Head Strap Replacement, Remove the front side foam pads: Schritt 7, Bild 2 von 3 HTC Vive Pro 2 Head Strap Replacement, Remove the front side foam pads: Schritt 7, Bild 3 von 3
      • Peel off both front side foam pads to uncover the speaker wires.
      Frag FixBot
    2. HTC Vive Pro 2 Head Strap Replacement, Remove the two rubber spacers: Schritt 8, Bild 1 von 3 HTC Vive Pro 2 Head Strap Replacement, Remove the two rubber spacers: Schritt 8, Bild 2 von 3 HTC Vive Pro 2 Head Strap Replacement, Remove the two rubber spacers: Schritt 8, Bild 3 von 3
      • Use the point of your spudger to pry out the two rubber spacers next to the headphone screws.
      • Be careful not to accidentally pry any of the speaker wires under the rubber spacer.
      Frag FixBot
    3. HTC Vive Pro 2 Head Strap Replacement, Disconnect the speaker wires: Schritt 9, Bild 1 von 3 HTC Vive Pro 2 Head Strap Replacement, Disconnect the speaker wires: Schritt 9, Bild 2 von 3 HTC Vive Pro 2 Head Strap Replacement, Disconnect the speaker wires: Schritt 9, Bild 3 von 3
      • Use the point of your spudger to pry up and disconnect both the left and right headphone speaker wires.
      Frag FixBot
    4. HTC Vive Pro 2 Head Strap Replacement, Remove the head strap: Schritt 10, Bild 1 von 2 HTC Vive Pro 2 Head Strap Replacement, Remove the head strap: Schritt 10, Bild 2 von 2
      • Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
      • Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
      • Four 3.9 mm screws (two on each side)
      • Two 4.1 mm screws (one on each side)
      Frag FixBot
    5. HTC Vive Pro 2 Head Strap Replacement: Schritt 11, Bild 1 von 1
      • Remove the two plastic spacers underneath the previously removed Torx T6 screw.
      Frag FixBot
    6. HTC Vive Pro 2 Head Strap Replacement: Schritt 12, Bild 1 von 3 HTC Vive Pro 2 Head Strap Replacement: Schritt 12, Bild 2 von 3 HTC Vive Pro 2 Head Strap Replacement: Schritt 12, Bild 3 von 3
      • Thread the headphone speaker wires out through both ends of the head strap.
      Frag FixBot
    1. HTC Vive Pro 2 Head Strap Replacement, Remove the front side foam pads: Schritt 13, Bild 1 von 3 HTC Vive Pro 2 Head Strap Replacement, Remove the front side foam pads: Schritt 13, Bild 2 von 3 HTC Vive Pro 2 Head Strap Replacement, Remove the front side foam pads: Schritt 13, Bild 3 von 3
      Frag FixBot
    2. HTC Vive Pro 2 Head Strap Replacement, Remove the two rubber spacers: Schritt 14, Bild 1 von 3 HTC Vive Pro 2 Head Strap Replacement, Remove the two rubber spacers: Schritt 14, Bild 2 von 3 HTC Vive Pro 2 Head Strap Replacement, Remove the two rubber spacers: Schritt 14, Bild 3 von 3
      Frag FixBot
    3. HTC Vive Pro 2 Head Strap Replacement, Disconnect the speaker wires: Schritt 15, Bild 1 von 2 HTC Vive Pro 2 Head Strap Replacement, Disconnect the speaker wires: Schritt 15, Bild 2 von 2
      Frag FixBot
    4. HTC Vive Pro 2 Head Strap Replacement, Remove the head strap: Schritt 16, Bild 1 von 2 HTC Vive Pro 2 Head Strap Replacement, Remove the head strap: Schritt 16, Bild 2 von 2
      Frag FixBot
    5. HTC Vive Pro 2 Head Strap Replacement: Schritt 17, Bild 1 von 1
      Frag FixBot
    6. HTC Vive Pro 2 Head Strap Replacement: Schritt 18, Bild 1 von 3 HTC Vive Pro 2 Head Strap Replacement: Schritt 18, Bild 2 von 3 HTC Vive Pro 2 Head Strap Replacement: Schritt 18, Bild 3 von 3
      Frag FixBot
Abschluss
Alex Diaz-Kokaisl
247.584 Reputation
1.203 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
123 Mitglieder
81.914 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 24
Insgesamt: 491
