Einleitung
Use this guide to replace one or both of the headphones on your HTC Vive Pro 2 headset.
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the procedure.
Power off and unplug your headset before you begin your repair.
Was du brauchst
Peel off the thin piece of padding covering the headphone screw for each headphone you're replacing.
Use your Phillips screwdriver to remove the 6.4 mm screw securing each headphone you are replacing.
Insert an opening pick under the headphone pad and pry up to unclip it from the headphone.
