Zum Hauptinhalt wechseln
HTC Vive Pro 2 Lens Assembly Replacement
Was du brauchst
    1. HTC Vive Pro 2 Lens Assembly Replacement, Reposition the head strap: Schritt 1, Bild 1 von 2 HTC Vive Pro 2 Lens Assembly Replacement, Reposition the head strap: Schritt 1, Bild 2 von 2
      • Rotate the head strap forward as far as it will go.
      Frag FixBot
      Kommentar hinzufügen
    2. HTC Vive Pro 2 Lens Assembly Replacement, Unplug the All-In-One Cable: Schritt 2, Bild 1 von 2 HTC Vive Pro 2 Lens Assembly Replacement, Unplug the All-In-One Cable: Schritt 2, Bild 2 von 2
      • Unplug the All-In-One Cable from your headset.
      Frag FixBot
    3. HTC Vive Pro 2 Lens Assembly Replacement, Remove the All-In-One Cable: Schritt 3, Bild 1 von 3 HTC Vive Pro 2 Lens Assembly Replacement, Remove the All-In-One Cable: Schritt 3, Bild 2 von 3 HTC Vive Pro 2 Lens Assembly Replacement, Remove the All-In-One Cable: Schritt 3, Bild 3 von 3
      • Remove the All-In-One Cable from the cable guides along the left side of the head strap.
      • During reassembly, connect the All-In-One Cable to the headset before routing it through the cable guides. This will ensure it has the right amount of slack.
      Frag FixBot
    1. HTC Vive Pro 2 Lens Assembly Replacement, Remove the top strap: Schritt 4, Bild 1 von 2 HTC Vive Pro 2 Lens Assembly Replacement, Remove the top strap: Schritt 4, Bild 2 von 2
      • Separate the top strap from itself where the Velcro secures it.
      Frag FixBot
    2. HTC Vive Pro 2 Lens Assembly Replacement: Schritt 5, Bild 1 von 3 HTC Vive Pro 2 Lens Assembly Replacement: Schritt 5, Bild 2 von 3 HTC Vive Pro 2 Lens Assembly Replacement: Schritt 5, Bild 3 von 3
      • Peel back the Velcro securing the rear of the top strap.
      • Feed the top strap out through the head strap to partially remove it.
      Frag FixBot
    3. HTC Vive Pro 2 Lens Assembly Replacement: Schritt 6, Bild 1 von 3 HTC Vive Pro 2 Lens Assembly Replacement: Schritt 6, Bild 2 von 3 HTC Vive Pro 2 Lens Assembly Replacement: Schritt 6, Bild 3 von 3
      • Feed the top strap through the clip near the front of headset to fully remove it.
      Frag FixBot
    1. HTC Vive Pro 2 Lens Assembly Replacement, Remove the front side foam pads: Schritt 7, Bild 1 von 3 HTC Vive Pro 2 Lens Assembly Replacement, Remove the front side foam pads: Schritt 7, Bild 2 von 3 HTC Vive Pro 2 Lens Assembly Replacement, Remove the front side foam pads: Schritt 7, Bild 3 von 3
      • Peel off both front side foam pads to uncover the speaker wires.
      Frag FixBot
    2. HTC Vive Pro 2 Lens Assembly Replacement, Remove the two rubber spacers: Schritt 8, Bild 1 von 3 HTC Vive Pro 2 Lens Assembly Replacement, Remove the two rubber spacers: Schritt 8, Bild 2 von 3 HTC Vive Pro 2 Lens Assembly Replacement, Remove the two rubber spacers: Schritt 8, Bild 3 von 3
      • Use the point of your spudger to pry out the two rubber spacers next to the headphone screws.
      • Be careful not to accidentally pry any of the speaker wires under the rubber spacer.
      Frag FixBot
    3. HTC Vive Pro 2 Lens Assembly Replacement, Disconnect the speaker wires: Schritt 9, Bild 1 von 3 HTC Vive Pro 2 Lens Assembly Replacement, Disconnect the speaker wires: Schritt 9, Bild 2 von 3 HTC Vive Pro 2 Lens Assembly Replacement, Disconnect the speaker wires: Schritt 9, Bild 3 von 3
      • Use the point of your spudger to pry up and disconnect both the left and right headphone speaker wires.
      Frag FixBot
    4. HTC Vive Pro 2 Lens Assembly Replacement, Remove the head strap: Schritt 10, Bild 1 von 2 HTC Vive Pro 2 Lens Assembly Replacement, Remove the head strap: Schritt 10, Bild 2 von 2
      • Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
      • Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
      • Four 3.9 mm screws (two on each side)
      • Two 4.1 mm screws (one on each side)
      Frag FixBot
    5. HTC Vive Pro 2 Lens Assembly Replacement: Schritt 11, Bild 1 von 1
      • Remove the two plastic spacers underneath the previously removed Torx T6 screw.
      Frag FixBot
    6. HTC Vive Pro 2 Lens Assembly Replacement: Schritt 12, Bild 1 von 3 HTC Vive Pro 2 Lens Assembly Replacement: Schritt 12, Bild 2 von 3 HTC Vive Pro 2 Lens Assembly Replacement: Schritt 12, Bild 3 von 3
      • Thread the headphone speaker wires out through both ends of the head strap.
      Frag FixBot
    1. HTC Vive Pro 2 Lens Assembly Replacement, Remove the outer shell: Schritt 13, Bild 1 von 3 HTC Vive Pro 2 Lens Assembly Replacement, Remove the outer shell: Schritt 13, Bild 2 von 3 HTC Vive Pro 2 Lens Assembly Replacement, Remove the outer shell: Schritt 13, Bild 3 von 3
      • The four screws securing the outer shell are covered with black stickers. If the stickers are difficult to remove, simply press your T6 Torx driver through them.
      Frag FixBot
    2. HTC Vive Pro 2 Lens Assembly Replacement: Schritt 14, Bild 1 von 2 HTC Vive Pro 2 Lens Assembly Replacement: Schritt 14, Bild 2 von 2
      • Use a T6 Torx screwdriver to remove the four 3.9 mm screws (two on top, two on bottom) securing the outer shell to the headset.
      Frag FixBot
    3. HTC Vive Pro 2 Lens Assembly Replacement: Schritt 15, Bild 1 von 3 HTC Vive Pro 2 Lens Assembly Replacement: Schritt 15, Bild 2 von 3 HTC Vive Pro 2 Lens Assembly Replacement: Schritt 15, Bild 3 von 3
      • Insert an opening pick into the seam between the two halves of the outer shell.
      • Slide the opening pick through the seam to dislodge the clips securing it to the headset.
      • Only insert the opening pick as far as necessary. There are ribbon cables underneath the outer shell.
      Frag FixBot
    4. HTC Vive Pro 2 Lens Assembly Replacement: Schritt 16, Bild 1 von 3 HTC Vive Pro 2 Lens Assembly Replacement: Schritt 16, Bild 2 von 3 HTC Vive Pro 2 Lens Assembly Replacement: Schritt 16, Bild 3 von 3
      • Continue sliding the opening pick through each seam until all clips have been dislodged.
      Frag FixBot
    5. HTC Vive Pro 2 Lens Assembly Replacement: Schritt 17, Bild 1 von 3 HTC Vive Pro 2 Lens Assembly Replacement: Schritt 17, Bild 2 von 3 HTC Vive Pro 2 Lens Assembly Replacement: Schritt 17, Bild 3 von 3
      • Carefully slide each half of the outer shell off of the sensor array.
      • Be careful not to snag any of the ribbon cables underneath.
      Frag FixBot
    1. HTC Vive Pro 2 Lens Assembly Replacement, Remove the face rest cushion: Schritt 18, Bild 1 von 3 HTC Vive Pro 2 Lens Assembly Replacement, Remove the face rest cushion: Schritt 18, Bild 2 von 3 HTC Vive Pro 2 Lens Assembly Replacement, Remove the face rest cushion: Schritt 18, Bild 3 von 3
      • Use your fingers to gently peel the face rest cushion off of the headset.
      Frag FixBot
    1. HTC Vive Pro 2 Lens Assembly Replacement, Disconnect the microphone: Schritt 19, Bild 1 von 2 HTC Vive Pro 2 Lens Assembly Replacement, Disconnect the microphone: Schritt 19, Bild 2 von 2
      • Use the point of your spudger, or a clean fingernail, to flip up the locking tab on the microphone ZIF connector on the daughterboard.
      Frag FixBot
    2. HTC Vive Pro 2 Lens Assembly Replacement: Schritt 20, Bild 1 von 2 HTC Vive Pro 2 Lens Assembly Replacement: Schritt 20, Bild 2 von 2
      • Use tweezers, or your fingers, to pull the microphone cable straight out of its socket.
      Frag FixBot
    3. HTC Vive Pro 2 Lens Assembly Replacement, Disconnect the sensor array: Schritt 21, Bild 1 von 2 HTC Vive Pro 2 Lens Assembly Replacement, Disconnect the sensor array: Schritt 21, Bild 2 von 2
      • Use tweezers, or your fingers, to peel the conductive fabric off the sensor array ZIF connector on the motherboard.
      Frag FixBot
    4. HTC Vive Pro 2 Lens Assembly Replacement: Schritt 22, Bild 1 von 2 HTC Vive Pro 2 Lens Assembly Replacement: Schritt 22, Bild 2 von 2
      • Use your spudger, or a clean fingernail, to flip up the locking tab on the sensor array ZIF connector.
      Frag FixBot
    5. HTC Vive Pro 2 Lens Assembly Replacement: Schritt 23, Bild 1 von 1
      • Use your fingers to grip the left and right sides of the sensor array cable and pull it straight out of its socket.
      Frag FixBot
    6. HTC Vive Pro 2 Lens Assembly Replacement, Remove the sensor array screws: Schritt 24, Bild 1 von 2 HTC Vive Pro 2 Lens Assembly Replacement, Remove the sensor array screws: Schritt 24, Bild 2 von 2
      • Use a T5 Torx screwdriver to remove the four 3.0 mm‑long screws securing the top of the sensor array.
      Frag FixBot
    7. HTC Vive Pro 2 Lens Assembly Replacement: Schritt 25, Bild 1 von 3 HTC Vive Pro 2 Lens Assembly Replacement: Schritt 25, Bild 2 von 3 HTC Vive Pro 2 Lens Assembly Replacement: Schritt 25, Bild 3 von 3
      • Use a T6 Torx screwdriver to remove the four 3.8 mm‑long screws securing the front of the sensor array.
      Frag FixBot
    8. HTC Vive Pro 2 Lens Assembly Replacement, Remove the sensor array: Schritt 26, Bild 1 von 2 HTC Vive Pro 2 Lens Assembly Replacement, Remove the sensor array: Schritt 26, Bild 2 von 2
      • Lift the sensor array straight off the lens assembly and remove it, making sure you thread the cable through its slot.
      • During reassembly, make sure the sensor assembly cable is threaded through its slot before continuing.
      Frag FixBot
    1. HTC Vive Pro 2 Lens Assembly Replacement, Remove the thermal pad: Schritt 27, Bild 1 von 3 HTC Vive Pro 2 Lens Assembly Replacement, Remove the thermal pad: Schritt 27, Bild 2 von 3 HTC Vive Pro 2 Lens Assembly Replacement, Remove the thermal pad: Schritt 27, Bild 3 von 3
      • Use your fingers to peel up the thermal pad covering the daughterboard.
      • The thermal pad will likely remove the Kapton tape from the ZIF connectors on the daughterboard. Replace the Kapton tape if necessary.
      • Set aside the thermal pad. You'll reuse it during reassembly.
      Frag FixBot
    2. HTC Vive Pro 2 Lens Assembly Replacement, Disconnect the lens assembly: Schritt 28, Bild 1 von 3 HTC Vive Pro 2 Lens Assembly Replacement, Disconnect the lens assembly: Schritt 28, Bild 2 von 3 HTC Vive Pro 2 Lens Assembly Replacement, Disconnect the lens assembly: Schritt 28, Bild 3 von 3
      • Insert the flat end of a spudger under a corner of the lens assembly press connector.
      • Don't insert your spudger anywhere else, as you risk dislodging nearby surface-mounted components.
      • Twist the spudger to lift the press connector up and disconnect it.
      • Repeat the same process to disconnect the other lens assembly press connector.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      Frag FixBot
    3. HTC Vive Pro 2 Lens Assembly Replacement, Disconnect the IPD sensor: Schritt 29, Bild 1 von 2 HTC Vive Pro 2 Lens Assembly Replacement, Disconnect the IPD sensor: Schritt 29, Bild 2 von 2
      • Use the point of a spudger to lift up the locking tab on the IPD sensor ZIF connector.
      Frag FixBot
    4. HTC Vive Pro 2 Lens Assembly Replacement: Schritt 30, Bild 1 von 2 HTC Vive Pro 2 Lens Assembly Replacement: Schritt 30, Bild 2 von 2
      • Use tweezers, or your fingers, to pull the IPD sensor cable straight out of its socket.
      Frag FixBot
    5. HTC Vive Pro 2 Lens Assembly Replacement, Disconnect the proximity sensor: Schritt 31, Bild 1 von 2 HTC Vive Pro 2 Lens Assembly Replacement, Disconnect the proximity sensor: Schritt 31, Bild 2 von 2
      • Use the point of a spudger to lift up the locking tab on the proximity sensor ZIF connector.
      Frag FixBot
    6. HTC Vive Pro 2 Lens Assembly Replacement: Schritt 32, Bild 1 von 2 HTC Vive Pro 2 Lens Assembly Replacement: Schritt 32, Bild 2 von 2
      • Use tweezers, or your fingers, to pull the proximity sensor cable straight out of its socket.
      Frag FixBot
    1. HTC Vive Pro 2 Lens Assembly Replacement, Remove the daughterboard screws: Schritt 33, Bild 1 von 2 HTC Vive Pro 2 Lens Assembly Replacement, Remove the daughterboard screws: Schritt 33, Bild 2 von 2
      • Use a T5 Torx screwdriver to remove the four 3.0 mm‑long screws securing the daughterboard.
      Frag FixBot
    2. HTC Vive Pro 2 Lens Assembly Replacement, Remove the daughterboard: Schritt 34, Bild 1 von 2 HTC Vive Pro 2 Lens Assembly Replacement, Remove the daughterboard: Schritt 34, Bild 2 von 2
      • Lift the daughterboard straight off the lens assembly and remove it.
      • During reassembly, make sure no cables are trapped under the daughterboard when placing it back on the headset.
      Frag FixBot
    1. HTC Vive Pro 2 Lens Assembly Replacement, The lens assembly remains: Schritt 35, Bild 1 von 1
      • Only the lens assembly remains.
      Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Alex Diaz-Kokaisl
247.308 Reputation
1.203 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
123 Mitglieder
72.066 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 16
Letzte 30 Tage: 69
Insgesamt: 1,045
