Zum Hauptinhalt wechseln
HTC Warhawk Buttons Replacement
Was du brauchst
  1. HTC Warhawk Buttons Replacement, Buttons: Schritt 1, Bild 1 von 1
    • Take the back cover off the phone and take the battery out.
  2. HTC Warhawk Buttons Replacement: Schritt 2, Bild 1 von 1
    • Take a SL#2.5 screwdriver and pop the black piece off shown here
  3. HTC Warhawk Buttons Replacement: Schritt 3, Bild 1 von 1
    • Take a T5 screwdriver and unscrew the two screws seen here
  4. HTC Warhawk Buttons Replacement: Schritt 4, Bild 1 von 1
    • Unscrew the two screws on the back of the phone with a T5 screwdriver
  5. HTC Warhawk Buttons Replacement: Schritt 5, Bild 1 von 2 HTC Warhawk Buttons Replacement: Schritt 5, Bild 2 von 2
    • Take the SL#2.5 screwdriver and pry off the back cover
    • The phone should now look like the second picture
  6. HTC Warhawk Buttons Replacement: Schritt 6, Bild 1 von 1
    • Take the SL#2.5 screwdriver and lift up the white connector at the top right corner of the phone on the side with the circuit board
  7. HTC Warhawk Buttons Replacement: Schritt 7, Bild 1 von 2 HTC Warhawk Buttons Replacement: Schritt 7, Bild 2 von 2
    • Next lift up the camera lens from the board.
    • It should now look like the second picture
    • Then lift up the circuit circled in red on the second picture
  8. HTC Warhawk Buttons Replacement: Schritt 8, Bild 1 von 2 HTC Warhawk Buttons Replacement: Schritt 8, Bild 2 von 2
    • Take the SL#2.5 screwdriver and pry off the volume buttons on the side of the phone
    • The circuit board should now be detached from the LCD part of the phone
  9. HTC Warhawk Buttons Replacement: Schritt 9, Bild 1 von 1
    • Next take the SL#2.5 screwdriver and pry the buttons off the phone and replace with the new ones
Abschluss
UW Stout, Team 5-3, Zhou Fall 2011 Mitglied von UW Stout, Team 5-3, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G3
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 781
