Zum Hauptinhalt wechseln
HTC Windows Phone 8S Display Assembly Replacement
Was du brauchst
Einführungsvideo
  1. HTC Windows Phone 8S Display Assembly Replacement, Loudspeaker: Schritt 1, Bild 1 von 3 HTC Windows Phone 8S Display Assembly Replacement, Loudspeaker: Schritt 1, Bild 2 von 3 HTC Windows Phone 8S Display Assembly Replacement, Loudspeaker: Schritt 1, Bild 3 von 3
    • Switch off the phone.
    • Remove the SIM / memory card cover.
    • Remove any SIM and memory cards.
    • Use screwdriver torx T5 and unscrew the two screws at the bottom of the battery / back cover.
  2. HTC Windows Phone 8S Display Assembly Replacement: Schritt 2, Bild 1 von 3 HTC Windows Phone 8S Display Assembly Replacement: Schritt 2, Bild 2 von 3 HTC Windows Phone 8S Display Assembly Replacement: Schritt 2, Bild 3 von 3
    • Use a plastic tool and slowly separate the back cover.
    • The loudspeaker is inside on the back cover.
  3. HTC Windows Phone 8S Display Assembly Replacement, Battery: Schritt 3, Bild 1 von 3 HTC Windows Phone 8S Display Assembly Replacement, Battery: Schritt 3, Bild 2 von 3 HTC Windows Phone 8S Display Assembly Replacement, Battery: Schritt 3, Bild 3 von 3
    • Use a Phillips #0 screwdriver and remove the 4x silver screws.
    • With a plastic tool carefully separate the battery from the logic board.
  4. HTC Windows Phone 8S Display Assembly Replacement: Schritt 4, Bild 1 von 3 HTC Windows Phone 8S Display Assembly Replacement: Schritt 4, Bild 2 von 3 HTC Windows Phone 8S Display Assembly Replacement: Schritt 4, Bild 3 von 3
    • The battery connector is under the middle frame. Remove it and disconnect the battery.
    • Model: BM59100 / 3,8VDC / 1700mAh
  5. HTC Windows Phone 8S Display Assembly Replacement, Flex Cables: Schritt 5, Bild 1 von 3 HTC Windows Phone 8S Display Assembly Replacement, Flex Cables: Schritt 5, Bild 2 von 3 HTC Windows Phone 8S Display Assembly Replacement, Flex Cables: Schritt 5, Bild 3 von 3
    • Remove the USB dock connector metal plate.
    • Open flex cable connectors:
    • LCD display flex cable
    • Menu buttons flex cable
    • Volume buttons flex cable
    • Touch screen flex cable
    • Power button flex cable
    • Pick up the vibrating motor and take out all flex cables except the LCD display flex cable.
  6. HTC Windows Phone 8S Display Assembly Replacement, Logic Board Removal: Schritt 6, Bild 1 von 3 HTC Windows Phone 8S Display Assembly Replacement, Logic Board Removal: Schritt 6, Bild 2 von 3 HTC Windows Phone 8S Display Assembly Replacement, Logic Board Removal: Schritt 6, Bild 3 von 3
    • The logic board is secured to the display frame by two locking clips.
    • Use a plastic tool to release it.
    • Now remove the LCD display flex cable from its connector.
  7. HTC Windows Phone 8S Display Assembly Replacement, Logic Board / Main Board: Schritt 7, Bild 1 von 2 HTC Windows Phone 8S Display Assembly Replacement, Logic Board / Main Board: Schritt 7, Bild 2 von 2
    • HTC Windows Phone 8S Logic Board.
  8. HTC Windows Phone 8S Display Assembly Replacement, Display Assembly: Schritt 8, Bild 1 von 3 HTC Windows Phone 8S Display Assembly Replacement, Display Assembly: Schritt 8, Bild 2 von 3 HTC Windows Phone 8S Display Assembly Replacement, Display Assembly: Schritt 8, Bild 3 von 3
    • Insert wisdom here.
  9. HTC Windows Phone 8S Display Assembly Replacement: Schritt 9, Bild 1 von 3 HTC Windows Phone 8S Display Assembly Replacement: Schritt 9, Bild 2 von 3 HTC Windows Phone 8S Display Assembly Replacement: Schritt 9, Bild 3 von 3
    • Check your spare part for the menu buttons flex cable.
    • Remove the flex cable from the old touch screen if you need.
  10. HTC Windows Phone 8S Display Assembly Replacement: Schritt 10, Bild 1 von 3 HTC Windows Phone 8S Display Assembly Replacement: Schritt 10, Bild 2 von 3 HTC Windows Phone 8S Display Assembly Replacement: Schritt 10, Bild 3 von 3
    • Clean the frame from the old adhesive tape.
    • Install new adhesive tape.
    • It would be better if you use adhesive sticker ready for the model.
    • Install the display assembly.
  11. HTC Windows Phone 8S Display Assembly Replacement: Schritt 11, Bild 1 von 3 HTC Windows Phone 8S Display Assembly Replacement: Schritt 11, Bild 2 von 3 HTC Windows Phone 8S Display Assembly Replacement: Schritt 11, Bild 3 von 3
    • Prepare the menu buttons and LCD display flex cables.
    • Start with reassembling.
    • Did you do it successfully?
Abschluss
ZFix
194.021 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
327 Mitglieder
1.697 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 2,797
