Zum Hauptinhalt wechseln
Einleitung
Make sure you complete previous guide.
  1. Power the phone off. Use your thumb to gently press downward and away from the camera to remove the battery cover.
    • Power the phone off.
    • Use your thumb to gently press downward and away from the camera to remove the battery cover.
  2. Pull on the plastic tab to release the battery. Pull on the plastic tab to release the battery.
    • Pull on the plastic tab to release the battery.
  3. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  4. Use a plastic opening tool to remove the camera cover. Work around the corners to avoid breaking the plastic clips that hold the camera cover on.
    • Use a plastic opening tool to remove the camera cover.
    • Work around the corners to avoid breaking the plastic clips that hold the camera cover on.
    • Lift the camera cover off of the phone.
  5. Remove the stylus from the phone.
    • Remove the stylus from the phone.
    • Remove the four 5.5 mm screws with the T6 Torx Screwdriver.
    • One of the screws might be under a sticker, which will void your warranty.
  6. Be Careful! Do not insert the spudger in between the keyboard and screen.  This could break the keyboard off the phone. If your phone contains a memory card, you may want to remove it before proceeding with this step. Insert spudger in the bottom corner as seen in the picture.  Carefully slide the spudger from the bottom towards the top as seen in the second picture.
    • Be Careful! Do not insert the spudger in between the keyboard and screen. This could break the keyboard off the phone.
    • If your phone contains a memory card, you may want to remove it before proceeding with this step.
    • Insert spudger in the bottom corner as seen in the picture. Carefully slide the spudger from the bottom towards the top as seen in the second picture.
    • Lift the back case off completely.
    • The speakers might be dangling and unsecured.
  7. Grip the speaker connector with your thumb and finger and gently pull up. Repeat for 2nd speaker.
    • Grip the speaker connector with your thumb and finger and gently pull up.
    • Repeat for 2nd speaker.
Abschluss
Taylor Stone
45 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 20-28, Maness Fall 2011 Mitglied von Cal Poly, Team 20-28, Maness Fall 2011
CPSU-MANESS-F11S20G28
4 Mitglieder
7 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 492
