Einleitung
This guide will display how to remove and install the back panel of the HTC Wizard 200.
Ersatzteile
Keine Ersatzteile angegeben.
Remove the back case with your fingernail to expose the battery. (Not shown in picture)
Pull the black tab to remove the battery.
Use a spudger to begin removal of the camera cover by inserting the flat end into the two notches and gently pry them up one at a time.
Use a T5 Torx screwdriver to remove four 6mm screws that secure the back panel to the main body.
Insert the flat end of a spudger into the crack between the front and rear cover.
Once you have enough of a gap to fit a plastic opening tool into it, use the opening tool to release the clips.
Use the plastic opening tool to continue releasing the clips until you have worked your way around the edge.
