Einleitung
This guide will explain how to install / remove the camera flash on the HTC Wizard 200.
Was du brauchst
To expose the battery, remove the outer case with your fingernail.
Remove the battery by pulling the black tab.
In diesem Schritt verwendetes Werkzeug:T5 Torx Screwdriver$5.49
Remove the four 6 mm screws with the T5 Torx screwdriver.
Insert the flat end of an iFixit opening tool between the side and inner covers to create a gap.
Work the tool around the edges until all the clips release.
