Einleitung
This guide will explain how to install / remove the keyboard slider on the HTC Wizard 200.
Ersatzteile
Keine Ersatzteile angegeben.
Remove the back case with your fingernail to expose the battery. (Not shown in picture)
Pull the black tab to remove the battery.
Use a spudger to begin removal of the camera cover by inserting the flat end into the two notches and gently pry them up one at a time.
Use a T5 Torx screwdriver to remove four 6mm screws that secure the back panel to the main body.
Insert the flat end of a spudger into the crack between the front and rear cover.
Once you have enough of a gap to fit a plastic opening tool into it, use the opening tool to release the clips.
Use the plastic opening tool to continue releasing the clips until you have worked your way around the edge.
Flip up the connector latch.
Use the tweezers to detatch the flexible connection.
Use your hands to gently expose the underside of the motherboard.
Use the spudger to pull off the flexible connection.
Use the T5 Torx screwdriver to remove four 5mm screws that secure the keyboard slider to the main body.
Ein weiterer Nutzer hat diese Anleitung absolviert.
