Zum Hauptinhalt wechseln
HTC Wizard 200 Screen Cover Replacement
Was du brauchst
  1. HTC Wizard 200 Screen Cover Replacement, Battery: Schritt 1, Bild 1 von 2 HTC Wizard 200 Screen Cover Replacement, Battery: Schritt 1, Bild 2 von 2
    • To expose the battery, remove the outer case with your fingernail.
    • Remove the battery by pulling the black tab.
  2. HTC Wizard 200 Screen Cover Replacement, Back Panel: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Spudger
    $3.99
    • Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
  3. HTC Wizard 200 Screen Cover Replacement: Schritt 3, Bild 1 von 2 HTC Wizard 200 Screen Cover Replacement: Schritt 3, Bild 2 von 2
    Spudger
    $3.99
    • Work the spudger around the edges of the camera cover until it comes off.
  4. HTC Wizard 200 Screen Cover Replacement: Schritt 4, Bild 1 von 2 HTC Wizard 200 Screen Cover Replacement: Schritt 4, Bild 2 von 2
    T5 Torx Screwdriver
    $5.49
    • Remove the four 6 mm screws with the T5 Torx screwdriver.
    • One of the screws is under the "void" sticker.
  5. HTC Wizard 200 Screen Cover Replacement: Schritt 5, Bild 1 von 3 HTC Wizard 200 Screen Cover Replacement: Schritt 5, Bild 2 von 3 HTC Wizard 200 Screen Cover Replacement: Schritt 5, Bild 3 von 3
    • Insert the flat end of an iFixit opening tool between the side and inner covers to create a gap.
    • Work the tool around the edges until all the clips release.
  6. HTC Wizard 200 Screen Cover Replacement: Schritt 6, Bild 1 von 2 HTC Wizard 200 Screen Cover Replacement: Schritt 6, Bild 2 von 2
    • Once all the clips are open, remove the inner panel from the phone.
  7. HTC Wizard 200 Screen Cover Replacement, Motherboard: Schritt 7, Bild 1 von 1
    Spudger
    $3.99
    • Use the spudger to pry the camera off.
  8. HTC Wizard 200 Screen Cover Replacement: Schritt 8, Bild 1 von 2 HTC Wizard 200 Screen Cover Replacement: Schritt 8, Bild 2 von 2
    • Using tweezers, flip the connector latch away from the motherboard.
    • Detach the flexible connection from under the connector latch.
  9. HTC Wizard 200 Screen Cover Replacement: Schritt 9, Bild 1 von 1
    • Slide the keyboard into the open position.
  10. HTC Wizard 200 Screen Cover Replacement: Schritt 10, Bild 1 von 2 HTC Wizard 200 Screen Cover Replacement: Schritt 10, Bild 2 von 2
    Spudger
    $3.99
    • Lift the motherboard out of the case using the spudger.
    • Expose the underside of the motherboard using your hands.
  11. HTC Wizard 200 Screen Cover Replacement: Schritt 11, Bild 1 von 2 HTC Wizard 200 Screen Cover Replacement: Schritt 11, Bild 2 von 2
    • Remove the flexible connection from the motherboard.
    • Caution: Removing the connection too fast may cause damage to the connection and cables.
  12. HTC Wizard 200 Screen Cover Replacement, Keyboard Slider: Schritt 12, Bild 1 von 3 HTC Wizard 200 Screen Cover Replacement, Keyboard Slider: Schritt 12, Bild 2 von 3 HTC Wizard 200 Screen Cover Replacement, Keyboard Slider: Schritt 12, Bild 3 von 3
    T5 Torx Screwdriver
    $5.49
    • Remove the four 5mm screws with the T5 Torx screwdriver.
    • Remove the keyboard slider from the main body.
  13. HTC Wizard 200 Screen Cover Replacement, Screen Cover: Schritt 13, Bild 1 von 2 HTC Wizard 200 Screen Cover Replacement, Screen Cover: Schritt 13, Bild 2 von 2
    • Use the T5 Torx screwdriver to remove four 5mm screws that secure the back of the screen casing.
  14. HTC Wizard 200 Screen Cover Replacement: Schritt 14, Bild 1 von 2 HTC Wizard 200 Screen Cover Replacement: Schritt 14, Bild 2 von 2
    • Insert the plastic opening tool between the front panel and the rear panel and pry open to reach the screen.
  15. HTC Wizard 200 Screen Cover Replacement: Schritt 15, Bild 1 von 2 HTC Wizard 200 Screen Cover Replacement: Schritt 15, Bild 2 von 2
    • Once the rear panel is loose, lift it off of the front panel.
    • The flexible connection will pop loose.
  16. HTC Wizard 200 Screen Cover Replacement: Schritt 16, Bild 1 von 1
    • Device rotated 90 degrees CCW.
    • Remove the yellow anti-static tape.
  17. HTC Wizard 200 Screen Cover Replacement: Schritt 17, Bild 1 von 2 HTC Wizard 200 Screen Cover Replacement: Schritt 17, Bild 2 von 2
    • Unscrew the two 3mm phillips #0 screws from the bottom of the device that secure the rigid flex board to the screen panel.
  18. HTC Wizard 200 Screen Cover Replacement: Schritt 18, Bild 1 von 1
    • Device rotated 180 degrees CW.
    • Unscrew the two 3mm phillips #0 screws from the top of the device that secure the rigid flex board to the screen panel.
  19. HTC Wizard 200 Screen Cover Replacement: Schritt 19, Bild 1 von 1
    • Unhinge the flexible connection and use the tweezers to disconnect.
  20. HTC Wizard 200 Screen Cover Replacement: Schritt 20, Bild 1 von 1
    • Now that the rigid flex board is loose, remove it from the screen.
Abschluss
Kyle Champ
225 Reputation
12 Anleitungen geschrieben
Cal Poly, Team 20-27, Maness Fall 2011 Mitglied von Cal Poly, Team 20-27, Maness Fall 2011
CPSU-MANESS-F11S20G27
4 Mitglieder
24 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 749
