Einleitung
This guide demonstrates the procedure for replacing a faulty camera in the HTC myTouch 3G.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Press each thumb on both sides of the upper corners and apply pressure downwards.
Then, while still applying pressure, slide the back cover down.
Remove the four 6-mm T5 torx screws in the four corners.
Remove the two 4-mm T5 torx screws in the middle.
Use the existing gap, to dislodge the antenna cover from the phone.
Pull out the antenna cover to have access to the motherboard.
Use a precision flathead screwdriver to dislodge the back plate from the phone by carefully inserting it into the slit between the frame and cover and pushing downward.
Go around the edges of the phone, and continue to dislodge the back plate from the front part of the phone.
Remove the 3-mm Phillips head screw located on the side of the bottom left-hand corner of the phone.
Remove the 3-mm Phillips head screw located on the top right-hand corner of the phone.
Place a finger between the circuit board and the front cover, and lift up gently.
Continue separating the circuit board from the front cover and screen and watch for a ribbon cable to detach.
Finish separating the circuit board from the front panel.
Turn the piece housing the circuit boards over to the side with the mounted camera.
Remove the three 3-mm Phillips head screws located on the top circuit board.
Locate the ribbon cable on the top circuit board.
Disconnect the ribbon cable by using a precision screwdriver to flip open the ribbon cable.
Slowly lift the circuit board from the left.
Continue to flip the circuit board all the way over to the right.
The other side of the camera and circuit board should be exposed.
Disconnect the ribbon cable with a precision screwdriver.
Remove the faulty camera and replace with a new one.
Ein weiterer Nutzer hat diese Anleitung absolviert.
