Einleitung
The Huawei Fit comes equipped with a spring loaded rubber strap. This guide will show the steps necessary to remove the strap for replacement with any 22mm spring loaded strap.
Was du brauchst
Insert the metal spudger tool into the outer edge of the latch component.
Hold the watch securely and press the spring latch component towards you with the metal spudger tool.
Eine weitere Person hat diese Anleitung absolviert.
