Einleitung
If the camera has been cracked or shows blurry pictures, it may need to be replaced.
Was du brauchst
To prepare the iOpener insert it in the microwave for 30 seconds and apply it on the side edges of the phone so that the glue underneath will soften.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use a plastic opening tool to pry up and disconnect the display cable from the motherboard.
Use tweezers to disconnect the white coax cable.
Use tweezers to disconnect the power and volume cable.
Use a plastic opening tool to pry up and disconnect the camera from the motherboard.
Use a plastic opening tool to pry the front camera connector from its socket on the motherboard.
