Zum Hauptinhalt wechseln
Hair Dryer Fan/ Motor Assembly Replacement
Was du brauchst
  1. Hair Dryer Fan/ Motor Assembly Replacement, Nozzle: Schritt 1, Bild 1 von 2 Hair Dryer Fan/ Motor Assembly Replacement, Nozzle: Schritt 1, Bild 2 von 2
    • Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
    • If nozzle is not attached, skip to next step.
  2. Hair Dryer Fan/ Motor Assembly Replacement, Grating: Schritt 2, Bild 1 von 1
    • Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
    • For most hair dryers, use a Phillips #1 screwdriver. For hair dryers with smaller screws, consider using a Phillips #00 screwdriver.
  3. Hair Dryer Fan/ Motor Assembly Replacement: Schritt 3, Bild 1 von 1
    • Detach the hair dryer grating from the body by gently twisting the grating from side to side.
  4. Hair Dryer Fan/ Motor Assembly Replacement: Schritt 4, Bild 1 von 1
    • Separate the hair dryer grating into the three pieces seen in the image.
  5. Hair Dryer Fan/ Motor Assembly Replacement, Fan/ Motor Assembly: Schritt 5, Bild 1 von 1
    • Locate the screws on the handle and remove with a Phillips screwdriver.
  6. Hair Dryer Fan/ Motor Assembly Replacement: Schritt 6, Bild 1 von 1
    • Carefully separate the plastic case with the Plastic Opening Tool.
  7. Hair Dryer Fan/ Motor Assembly Replacement: Schritt 7, Bild 1 von 1
    • After removing the plastic case, locate the fan towards the back of the hair dryer.
  8. Hair Dryer Fan/ Motor Assembly Replacement: Schritt 8, Bild 1 von 1
    • Remove the screw that is holding the fan to the motor using a Phillips screwdriver.
  9. Hair Dryer Fan/ Motor Assembly Replacement: Schritt 9, Bild 1 von 1
    • Remove the screws holding the motor to the casing using a Phillips screwdriver.
    • NOTE: This may be unnecessary if the fan can be removed without using a screwdriver.
  10. Hair Dryer Fan/ Motor Assembly Replacement: Schritt 10, Bild 1 von 1
    • Isolate the fan from the rest of the dryer.
    • Remove the screws holding the motor in place. Replace with the new component.
  11. Hair Dryer Fan/ Motor Assembly Replacement: Schritt 11, Bild 1 von 1
    • Solder the wires to the motor. Refer to the soldering page below, which will help you replace this component.
    • Soldering Skills
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Mitch
34 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 24-29, Regan Fall 2012 Mitglied von Cal Poly, Team 24-29, Regan Fall 2012
CPSU-REGAN-F12S24G29
5 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 20
Letzte 30 Tage: 59
Insgesamt: 16,591
