Zum Hauptinhalt wechseln
Hair Dryer Grating Replacement
Was du brauchst
  1. Hair Dryer Grating Replacement, Nozzle: Schritt 1, Bild 1 von 2 Hair Dryer Grating Replacement, Nozzle: Schritt 1, Bild 2 von 2
    • Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
    • If nozzle is not attached, skip to next step.
  2. Hair Dryer Grating Replacement, Grating: Schritt 2, Bild 1 von 1
    • Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
    • For most hair dryers, use a Phillips #1 screwdriver. For hair dryers with smaller screws, consider using a Phillips #00 screwdriver.
  3. Hair Dryer Grating Replacement: Schritt 3, Bild 1 von 1
    • Detach the hair dryer grating from the body by gently twisting the grating from side to side.
  4. Hair Dryer Grating Replacement: Schritt 4, Bild 1 von 1
    • Separate the hair dryer grating into the three pieces seen in the image.
Abschluss
Mitch
34 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 24-29, Regan Fall 2012 Mitglied von Cal Poly, Team 24-29, Regan Fall 2012
CPSU-REGAN-F12S24G29
5 Mitglieder
11 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 24
Insgesamt: 2,598
