Zum Hauptinhalt wechseln
Hamilton Beach 25460Z Handle Replacement
Was du brauchst
  1. Hamilton Beach 25460Z Handle Replacement, Handle: Schritt 1, Bild 1 von 2 Hamilton Beach 25460Z Handle Replacement, Handle: Schritt 1, Bild 2 von 2
    • Unplug your device before proceeding with disassembly.
    • On the back of the press, remove the locking washer by prying upwards with the nylon or metal spudger tool.
    • Repeat for the other washer across from the first one.
  2. Hamilton Beach 25460Z Handle Replacement: Schritt 2, Bild 1 von 2 Hamilton Beach 25460Z Handle Replacement: Schritt 2, Bild 2 von 2
    • Using any long, thin object, push the 43mm bolt from the inside towards the outside to expose the end of the bolt.
    • Pull the end of the bolt out to completely remove it.
    • Repeat for the second bolt.
  3. Hamilton Beach 25460Z Handle Replacement: Schritt 3, Bild 1 von 2 Hamilton Beach 25460Z Handle Replacement: Schritt 3, Bild 2 von 2
    • Using the 4.0mm Allen Wrench, unscrew the two 26mm bolts connecting the handle to the upper heating element housing on both sides.
  4. Hamilton Beach 25460Z Handle Replacement: Schritt 4, Bild 1 von 1
    • Unscrew the locking knob all the way to remove it.
  5. Hamilton Beach 25460Z Handle Replacement: Schritt 5, Bild 1 von 3 Hamilton Beach 25460Z Handle Replacement: Schritt 5, Bild 2 von 3 Hamilton Beach 25460Z Handle Replacement: Schritt 5, Bild 3 von 3
    • Slide the locking knob couple down to the base of the handle, then pull up on the free end of the handle. It will easily pop off.
Abschluss
Cal Poly, Team 6-27, Amido Winter 2015 Mitglied von Cal Poly, Team 6-27, Amido Winter 2015
CPSU-AMIDO-W15S6G27
4 Mitglieder
6 Anleitungen geschrieben
2 Kommentare
And where do I buy the handle?? I can’t find it anywhere
if someone see this, please help me!
Tulio
Tulioalejandro@icloud.com
tulio181 - Antwort
I too am looking for a replacement handle! They get brittle from the heat...mine just snapped on the left side..
salikah11@yahoo.ca
DEE EFF - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 15
Insgesamt: 1,619
