Einleitung
This is a straight-forward process that requires removal of a few screws and two wire caps.
Was du brauchst
Remove the four 14mm screws from the bottom of the Panini Press using the T10 Screwdriver.
Use the pliers to pinch the widest point of the cap. This should be done opposite of the already existing crimps.
Slide off the white cap.
Repeat these steps for the second white cap.
Remove the two rubber screw covers from the bottom of the Panini Press.
Remove the four uncovered 10mm screws with the PH2 Screwdriver.
Lift the plastic lower heating element up and place to the side for reassembly. You have now disconnected the plug wiring completely.
To reassemble your device, follow these instructions in reverse order. Make sure to correctly replace the wires using tape you placed earlier as a reference.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
