Einleitung
This replacement requires you to be confident with simple wiring as well as basic soldering skills. If you are unfamiliar with soldering and de-soldering, make sure to check out iFixit's Soldering Skills page before attempting this replacement!
Was du brauchst
Remove the four 14mm screws from the bottom of the Panini Press using the T10 Screwdriver.
Use the pliers to pinch the widest point of the cap. This should be done opposite of the already existing crimps.
Slide off the white cap.
Repeat these steps for the second white cap.
Remove the two rubber screw covers from the bottom of the Panini Press.
Remove the four uncovered 10mm screws with the PH2 Screwdriver.
Lift the plastic lower heating element up and place to the side for reassembly. You have now disconnected the plug wiring completely.
Remove the two 10mm screws connecting the thermal switch with the PH2 Screwdriver and a bit of force.
De-solder the connection between the wires and the thermal switch.
Replace the thermal switch.
The lead on the red (with the small hole), marked in red, connects to the white wire.
The lead on the right, marked in blue, connects to the blue wire.
