Einleitung
This is the disassembly guide for the Hamilton Beach 31334Z toaster oven. This guide will allow you to access the heating elements as well as the timer and thermostat circuitry for user-servicing.
Was du brauchst
Tilt the door into the open position and pull straight up and away from the rest of the oven.
Place the oven upside down so the bottom is accessible.
Remove the rubber feet with fingers (or pliers) to reveal the screws on each foot underneath.
Remove the two Phillips screws on the outer edges of the bottom of the oven as shown.
Remove the three countersunk, 9 mm Phillips head screws along the dark grey curve.
Remove the three Phillips screws on the inside edge of the oven, as shown.
On the other side, remove the 3 countersunk Phillips head screws above the dark grey panel.
Remove the two Phillips screws on the inside edge of the panel next to the knobs as shown.
