Einleitung
Before starting, you should be sure to unplug the coffee maker. Also, me sure to empty all contents before making any repairs.
Was du brauchst
This is what the bottom cover will look like. Flip the Brew Station upside down to easily access the screws.
Using the Philips 2 Screwdriver, unscrew the three 8-mm screws labeled in a red outline.
Using the Crown Bolt #8 Steel Spanner, unscrew the two 8-mm screws labeled in a orange outline.
Carefully slide off the bottom drip tray by sliding it out away from the Brew Station.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
