Zum Hauptinhalt wechseln
Hamilton Beach 48464 Heating Plate Replacement
Was du brauchst
  1. Hamilton Beach 48464 Heating Plate Replacement, Heating Plate: Schritt 1, Bild 1 von 1
    • To begin, carefully open the top lid of the Brew Station.
  2. Hamilton Beach 48464 Heating Plate Replacement: Schritt 2, Bild 1 von 1
    • Gently pull out the filter basket from the Brew Station and set it to the side.
  3. Hamilton Beach 48464 Heating Plate Replacement: Schritt 3, Bild 1 von 1
    • Grab the handle and pull up to remove the top container.
    • Set this piece close by as you will be needing it for a future step.
  4. Hamilton Beach 48464 Heating Plate Replacement: Schritt 4, Bild 1 von 2 Hamilton Beach 48464 Heating Plate Replacement: Schritt 4, Bild 2 von 2
    • Using the Crown Bolt #8 Steel Spanner, unscrew the four 8-mm screws labeled in a red outline.
  5. Hamilton Beach 48464 Heating Plate Replacement: Schritt 5, Bild 1 von 2 Hamilton Beach 48464 Heating Plate Replacement: Schritt 5, Bild 2 von 2
    • Check again to make sure that the coffee maker is not plugged in.
    • Once the screws are removed, carefully pull off the metal piece.
    • Once the piece is removed, you will be able to access the heater.
  6. Hamilton Beach 48464 Heating Plate Replacement: Schritt 6, Bild 1 von 2 Hamilton Beach 48464 Heating Plate Replacement: Schritt 6, Bild 2 von 2
    • This step involves using the top contained that you put aside in step 3.
    • Using the Philips 2 Screwdriver, unscrew the eight 8-mm screws labeled in a red outline.
  7. Hamilton Beach 48464 Heating Plate Replacement: Schritt 7, Bild 1 von 1
    • Once screws are removed, carefully pull out the metal piece from the unit. This is the top part of the heater in the Brew Staton.
    • There are rubber washers inside each of the 8 holes on the piece of metal. Be careful to not let any fall out when handling the piece.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team 14-1, Lacy Spring 2016 Mitglied von USF Tampa, Team 14-1, Lacy Spring 2016
USFT-LACY-S16S14G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 8
Letzte 30 Tage: 14
Insgesamt: 947
