Einleitung
This guide shows you how to remove the tubing found inside the Brew Station. This is helpful when you want to replace it for a cleaner tube. Tweezers for the removal of the tube is highly suggested.
Was du brauchst
Using the Philips 2 Screwdriver, unscrew the two 8-mm screws labeled in a red outline.
Once screws are removed, pull off the little circle piece.
Using tweezers, grab the tube that is exposed after you pulled the piece off in step 1 and pull it up and out of the Brew Station.
Using the Philips 2 Screwdriver, unscrew the three 8-mm screws labeled in a red outline.
Once screws are removed, gently pull off the liner that is on the inside of the lid.
After completing Step 3, you will be exposed to a little piece attached to the inside of the lid. Pull this piece out, as it is the last piece of tubing used in the Brew Station.
