Zum Hauptinhalt wechseln
Hamilton Beach 49980A Motherboard Replacement
Was du brauchst
  1. Hamilton Beach 49980A Motherboard Replacement, Bottom Plate: Schritt 1, Bild 1 von 3 Hamilton Beach 49980A Motherboard Replacement, Bottom Plate: Schritt 1, Bild 2 von 3 Hamilton Beach 49980A Motherboard Replacement, Bottom Plate: Schritt 1, Bild 3 von 3
    • Begin by inverting the coffee maker and resting it on a flat surface to make working on the bottom easier.
    • Now use a Y0 bit to remove all of the .46 inch long screws from the bottom.
    • Lift the plate to remove it from the rest of the machine.
  2. Hamilton Beach 49980A Motherboard Replacement, Motherboard: Schritt 2, Bild 1 von 1
    • Once the bottom plate is removed, use a PH1 bit to remove the .525 inch long screws holding the motherboard bracket in the main housing.
  3. Hamilton Beach 49980A Motherboard Replacement: Schritt 3, Bild 1 von 2 Hamilton Beach 49980A Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Using a PH1 bit, remove the two .425 inch long screws holding down the white power cord bracket. This will give you the slack in the wire that you need to work on the motherboard.
    • Carefully remove the large white connector that has multiple wires attached to it. This is the wire connected to the button functions on the interface of the coffee maker.
Abschluss
UMass Dartmouth, Team 1-7, Miles Spring 2016 Mitglied von UMass Dartmouth, Team 1-7, Miles Spring 2016
UMASSD-MILES-S16S1G7
3 Mitglieder
21 Anleitungen geschrieben
1 Kommentar zur Anleitung
very informative and helpful.    I am anal about trying to repair different appliances.    I despise ‘throw away  and replace’  philosophy.   now I need to determine how to purchase a new motherboard.   at this point, I draw the line is trying to diagnosis and repair one.…………
john - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 871
